enabling ssh on ws-3750-12s
s.ghouse123
i want to enable SSH on my ws-3750-12s swich, sw ver 12.2(25)SEE2  please guide me.
does this model  fast ethernet ws-c2960-48TC-L supports SSH
Mohsin Alam
In order to have ssh functionality in devices you need to have a cryptography image ios with name called K9.
e.g. : C3750-IPBASEK9-M
Once you have your IOS upgraded, define hostname, domain name, generate crypto RSA key, and transport input commands on the VTY lines to have it converted to SSH.
## Make sure to mark post as helpful, If it resolved your issue. ##
on a side note, I am not sure you can still download newer IOS versions for these models. The 2960-48TC-L is end of support for a couple of years, and the WS-3750-12S sounds rather old as well. What are the exact product numbers of your switches ?
Hello
(hostname not applicable)
conf t
username xxxx privilege 15 secret xxx
crypto key generate rsa label LOCAL-KEY general modulus 2048
ip ssh ver 2
line vty 0 4
login local
transport input ssh
Kind Regards
Paul
