Encounter FTP error on Nexus 5548
wmchan1979
Hi all,
I encountered problem while trying to copy file from Nexus 5548 to my ftp server (proteus - 192.168.12.220 - the Nexus switch is able to resolve name proteus correctly to 192.168.12.220). See below the working and not working scenarios. I have serached through Cisco Bug Database but unable to find any related bug associated to this problem. This Nexus is running the following NX-OS version.
n5000-uk9-kickstart.5.1.3.N1.1a.bin
n5000-uk9.5.1.3.N1.1a.bin
Could anyone help? Thanks.
Working (without specifying the username and full path)
SY-SW-STAG5K-01# copy ftp://proteus bootflash: vrf management
Enter source filename: MDS20120902172106548.lic
Warning: There is already a file existing with this name. Do you want to overwrite (y/n)? [n] y
Enter usernme: public
Password:
*****Transfer of file Completed Successfully*****
Copy Complete, now saving to disk (please wait)...
SY-SW-STAG5K-01#
Not Working (by specifying the username and full path)
SY-SW-STAG5K-01# copy ftp://public@proteus/MDS20120902172106548.lic bootflash: vrf management
Password:
Failed to open file.
***** Transfer of file aborted, file not found or Login failed*****
Error during copy
*****Transfer of file aborted*****
Woei Mun Chan
phiharri
Greetings,
Unfortunately I do not believe specifying the username in an FTP URL is currently supported on NX-OS. Refer to Table 2 in the command reference for the 'copy' command:
ftp:
Source or destination URL for a FTP network server. The syntax for this alias is as follows:
ftp:[//server][/path]/filename
Cisco Nexus 5000 Series NX-OS Fundamentals Command Reference - C Commands
Kind Regards,
/Phil
