Encryption module for cisco router 3845
ssweehinlew
Can the encryption module (DES/ 3DES/AES/SSL VPN Encrytion/compression) for Cisco Router 3845 able to support the external connection from other high end router, for example cisco 7200? What is the maximum bandwidth, load and concurrent connection it can support? If possible, please kindly provide the supporting document. Thanks.
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/data_sheet_vpn_aim_for_18128003800routers_ps5853_Products_Data_Sheet.html
You find stuff like these the followin way:
www.cisco.com/go/3800 -> Interfaces and Modules -> VPN and Security Modules
