entering ip address in bit count format
mhdganji110
Hi !
as we know, you can specify that the display of the  network mask appear in hexadecimal format or bit count format instead.  The hexadecimal format is commonly used on UNIX systems. The previous  example would be displayed as 131.108.11.55 0XFFFFFF00.
but I like to enter my address in this way
I mean instead of
int fa 0/0
i like to use 192.168.1.1 / 24
we have to enter many addresses in many interfaces and this would help me a lot  and also no need to convert /22 to ... hmm 255.255.252 and ..
thanks
cadet alain
As far as I know this is not supported as of yet at least on IOS platforms.
Regards.
Alain.
