Eol or EoS for
qwertys21
Hi All
I have a Cat 4503 running CatOS. I have just checked the website and know that supervisor card WS-X4013 is now EoL for Cat 4000.
Is it EoL also for Cat 4503?
1 1 2 1000BaseX Supervisor WS-X4013 no ok
2 2 48 10/100/1000 Ethernet WS-X4448-GB-RJ45 no ok
3 3 48 10/100/1000 Ethernet WS-X4448-GB-RJ45 no ok
11 Replies 11
Martin Parry
Level 3
Level 3
The supervisor engine is EOL independant of which chassis it is in.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps663/ps668/prod_end-of-life_notice09186a0080225602.html
Hope this helps
Martin
Is this really correct.
Looking at this link http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5347/product_data_sheet09186a0080197424_ps4324_Products_Data_Sheet.html
shows that Cisco Catalyst 4500 Series Supervisor Engine II-Plus
(WS-X4013+) is still very much alive.
Please help.
But you stated in your original post that your enquiry regarded the WS-X4013 SUP 2. These went EOS May 2005
Martin
Thanks Martin
It shows on my show mod
Is this the same as WS-X4013 SUP 2. This is really confusing as I need to be sure I am not saying a device is EoL when it is not.
So what I have is a Cat 4503 with
Mod Slot Ports Module-Type Model Sub Status
Is the
1 1 2 1000BaseX Supervisor WS-X4013 end of life?
Thank for your help.
Hi Friend,
WS-X4013 is SUP 2 and WS-X4013+ is SUP2 Plus.
WS-X4013 only supports CATOS and is now EOL but SUP2+ supports IOS and is still supported on 4500 chassis.
What you have is SUP2 which is EOL.
Ankur
*Pls rate all helpfull post
Thank you
Yes, WS-X4013 is EOL/EOS and no longer available. You can replace that with the SUP2+, Sup2+10GE, Sup4/Sup5/Sup5+10GE.
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html
-amit singh
FWIW, this is what a sh module looks like for a Sup II+ 4503
Chassis Type : WS-C4503
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 2 Supervisor II+ 1000BaseX (GBIC) WS-X4013+ JAE00000000
2 48 10/100/1000BaseT (RJ45)V, Cisco/IEEE WS-X4548-GB-RJ45V JAE00000000
3 48 10/100/1000BaseT (RJ45)V, Cisco/IEEE WS-X4548-GB-RJ45V JAE00000000
This is what I get on the show module on another Cat 4503 running IOS. Is this Sup or Sup II and is this EoL? It does not explicitly say Supervisor II+ like yours says.
1 2 1000BaseX (GBIC) Supervisor(active) WS-X4013+ JAE07350945
2 48 10/100/1000BaseTX (RJ45) WS-X4448-GB-RJ45 JAB080908KP
But it does say WS-X4013+ which is Sup2+. The SUP2 only runs CAT OS, wo the fact that you are running IOS is another indication you have a SUP2+ in that chassis.
Martin
Thank you. Now I can be sure of what I am saying. Thank ou very much
