Erasing port config after module removal.
sscaria
I have a 6500 switch and i recently removed a module (line card) from the switch. The problem is that the port configurations of the removed module still exhists in running configuration.
I was not aware of the right procedure,http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a008086ed2e.shtml
however, i would like to know whether it resolves if i reboot the switch.
thanks,
sony
Benjamin Kools
A reboot will remove the config from the running configuration. If you watch the log you'll see the startup config error out as it tries to put in the lines of the config specific to the missing module. Just do a copy run start at that point and your startup config will reflect the change as well.
If you do not want to have to reboot the switch, put the line card back in, issue the module clear-config command and remove the module again. This will remove the configuration without a reboot.
