Routing/Switching Design
ciscogeek090
See attached diagram.
We have 2 data centres which are connected together via a layer 3  point-to-point link and 1 office which is connected to each of the data centres  using metro ethernet. The interfaces connecting the metro ethernet will be  routed ports as we dont want broadcast traffic reaching the data centres
The office Cisco 3750 switches will be configured with HSRP to provide first  hop redundancy for connected devices.
We need to configure the networking to be fully resilient, so in the event  that the primary link fails to DC1, all traffic routes to DC2 via the second  link. I can see that this will be messy with static routes and floating static  routes as a line failure might not cause the 3750 interface line protocols to  drop (there will be local devices provided by the telco for the circuits)
I'm assuming that we will need to use OSFP/EIGRP but we only have ipbase  licensing. Is there anyway to acheieve this without using an IGP?
5 Replies 5
mvsheik123
Level 7
Level 7
What about RIP (ofcourse- old though)? Also, I guess IPbase support EIGRP stub nw feture. You may wanr to look into that as well.
Thx
MS
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
As MS mentions, RIP may be an option.  Believe IP base supports RIPv2, too.
PS:
I'm curious why you're using HSRP between your two 3750s and not stacking them.
Mert OZKUL
You can use IP Sla for this case.
1-) Continuously ping the DC1 wan interface from your "3750 1" wan interface.
2-) If the SLA fails, according to your SLA timers, change the static routes with tracking.
Example Configuration;
ip sla1
icmp-echo 2.2.2.2 source-interface fastethernet0/0
timeout 1000
threshold 2
frequency 3
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
ip route 0.0.0.0 0.0.0.0 2.2.2.2 track 1
ip route 0.0.0.0 0.0.0.0 3.3.3.3 10
First check the sla working correctly or not with the "show ip sla" commands.
BR,
Mert ÖZKUL
Is IP SLA available under the IP Base license? Will it be possible to use route tracking with HSRP?
IP SLA and Route Tracking (called Enhanced Tracking Support/Enhanced Object Tracking) are both supported on the 3750 with an IP Base license. You can use feature navigator to verify:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
