err-disable WS-X45-SUP7L-E' switch model.
ddesai
I have recently configured port security in all ports only two ports error-disable and after i have shut no shut but no luck. I tried mode auto and full duplex but no luck.
anyone can help?
26 Replies 26
switchport port-security mac-address sticky <<- we decide to remove this command ?? why you add it again ?
Okay Will do again default port and do it and update the same.
Typo error sorry about that.
still same issue as per following configuration. This switch random ports are going to error -disable till now 2 ports are facing same issue all ports configuration is same.
interface GigabitEthernet5/46
switchport access vlan XX
switchport mode access
switchport voice vlan XX
switchport port-security maximum 10
auto qos voip cisco-softphone
spanning-tree portfast edge
spanning-tree bpduguard enable
service-policy input AutoQos-4.0-Cisco-Softphone-Input-Policy
service-policy output AutoQos-4.0-Output-Policy
end
CLEV-SR-IDF-2#show int gi5/46
GigabitEthernet5/46 is down, line protocol is down (err-disabled)
Hardware is Gigabit Ethernet Port, address is a0ec.f99e.b5e3 (bia a0ec.f99e.b5e3)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, link type is auto, media type is 10/100/1000-TX
input flow-control is off, output flow-control is off
Auto-MDIX on (operational: on)
Last input 00:00:14, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 264674
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
5 minute output rate 43000 bits/sec, 1 packets/sec
1865177404 packets input, 1361813692712 bytes, 0 no buffer
Received 4161589 broadcasts (4043611 multicasts)
If i will bounce port than again it will going to error disable. It was working only if I will remove disable port security.
Do these steps
Show mac address
Check the mac of pc and phone
Then do
Show running
So you see staitc maç address of pc and phone appear in running  config?
Show mac address command showing me two mac but configuration show run not showing me any mac address
CLEV-SR-IDF-2#show mac address-table | in GigabitEthernet5/46
  20      24d9.2147.21c1   dynamic ip,ipx,assigned,other GigabitEthernet5/46
  40      806d.9725.12f7   dynamic ip,ipx,assigned,other GigabitEthernet5/46
switchport access vlan 40
switchport voice vlan 20
Can I see show running
MHM
Do you mean whole configuration ?
Yes, hide any public IP and share here
ddesai
Earlier we have configured 802.11 authenticate. does that affect anything.
Random ports going to error disable after allow 10 mac address
 ip dhcp snooping vlan xx
no ip dhcp snooping information option
ip dhcp snooping
ip device tracking probe auto-source
vtp mode transparent
authentication mac-move permit
access-session acl default passthrough
epm logging
dot1x system-auth-control
diagnostic bootup level complete
errdisable recovery cause link-flap
errdisable recovery interval 60
power redundancy-mode redundant
spanning-tree mode pvst
redundancy
mode sso
Alot' port security with 802.1x not work together' or work but with limitations.
So select one of them.
MHM
can i remove following few commands from switch?
ip dhcp snooping
epm logging
redundancy
mode sso
