Err-Discard on X2-10-GB-LRM (3750 & 4507)
Zaid Farooqui
we have a core switch 4507RE at the data center and 2 departments that connect to it via 10Gig fiber using X2-LRM modules.
Each department  has a 3 switch stack and both locations are identical w.r.t type and setup scenario ..
the stack comprises of  1 x 3750E and 2 x 3750G . uplink is from X2 port tengig3/0/1 from the 3750E switch.
all of a sudden dept B started facing problem , where the ping would break and throughput comes around 6 - 7 mbps   from that dept to the server behind the core switch.   we also noted CRC error on both sides preodically ...   so ....
we replaced the multimode fiber patch cords, re did the splicing , which  stopped the CRC errors to appear.
now since morning the uplink port on the 3750E (3/0/1) would suddenly be in "down" state    with (err-disabled) as the status  when i run sh int ten 3/0/1
and i can also see CRC errors and input errors on the same interface..   if i do shut / no shut .. the port is up and active again..    but this has happned 3 times today..
the core swith side is still OK and no CRC / input / output  errors are seen..
now on the 3750E i have  swapped the 10gig module from 3/0/1 to 3/0/2 .  the port is still up but i can see 400 CRC and 500 Input errrors.....
the module is also OK as i had replaced it with dept 1's module....
any anyone please suggest what and how to check ... im totally blank ..  which side has the problem ..... how to trace it
Leo Laohoo
Input errors??  This means the problem is coming from the 4507-side.
Replace the 10Gb module (module issue?) on the 4507-side and/or move to a different slot (line card issue?).
