05-10-2013 07:52 AM - edited 03-07-2019 01:17 PM
I am getting a loopback error on the errdisable. I do a int gigeth2/0/38 and do a shut and no shut but the link light still stays orange with nothing connected into it.
If I connect my laptop to that port and let it initialize the link light goes green and the orange goes away. The only issue is I don't know what is causing that port to go into errdisable or what is causing the link light to stay orange.
Any ideas?
05-10-2013 08:06 AM
When you do "sh int gi2/0/38" does it show the port is in errordisable?
also, can you post the config for interface 2/0/38?
05-10-2013 08:21 AM
Also, can you post any port security config,?
05-10-2013 09:03 AM
interface GigabitEthernet2/0/38
switchport access vlan 95
switchport mode access
GigabitEthernet2/0/38 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is b0fa.eb38.7926 (bia b0fa.eb38.7926)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
Media-type configured as connector
input flow-control is off, output flow-control is unsupported
Last input never, output 02:02:43, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
91 packets input, 16056 bytes, 0 no buffer
Received 91 broadcasts (14 multicasts)
0 watchdog, 14 multicast, 0 pause input
1264 packets output, 124522 bytes, 0 underruns
0 output errors, 10 collisions, 5 interface resets
05-10-2013 10:45 AM
Hello
Apart from the laptop connecting to this port what are you connecting when this port error disables? - Attach whatever that is and then.
sh int 2/0/38 status
sh spanning-tree summary
sh log
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
