error detected on gi1/9
ilnaiduccna
Hi folks,
As per the logs created I found the following errors on the port gi1/9
ERROR "link-flap error detected on Gi1/11, putting Gi1/11 in err-disable state"
Jul 2 16:25:15 gmt: %PM-SP-4-ERR_DISABLE: link-flap error detected on Gi1/9, putting Gi1/9 in err-disable state
Jul 2 16:25:15 gmt: %PM-SP-STDBY-4-ERR_DISABLE: link-flap error detected on Gi1/9, putting Gi1/9 in err-disable state
Jul 2 16:47:55 gmt: %PM-SP-4-ERR_DISABLE: link-flap error detected on Gi1/8, putting Gi1/8 in err-disable state
Jul 2 16:47:55 gmt: %PM-SP-STDBY-4-ERR_DISABLE: link-flap error detected on Gi1/8, putting Gi1/8 in err-disable state
Naidu.
Hi Naidu,
Link flap error occurs when the interface/link goes Up / down very frequently. most often its the physical layer problem - so check the cable / duplex / gbic converter.
For more detailed help check this link
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00806cd87b.shtml
Hope this helps,
dhananjoy
Hi Dananjoy,
Thanks for your early reply.
Present I am at remote location need to coordinate with on site persons.
As you told I understood about cable, duplex except gbic converter.
Can you tell brief about gbic converter?
Naidu.
Actually I meant GBIC(gigabit interface converter) card.
