Error in logging observed on 6513 switch
akhil.abrol
I have been getting the logs in my cisco 6513 switch
show logging | b Jul 16
00:08:32.140 FW[Mod 09]: AR#1
[0x00C3]           ME_AR_FIF_A2F_FCTL_STATE = 0x00AA
[0x00C4]           ME_AR_FIF_F2A_FCTL_STATE = 0x8888
[0x017E]               ME_AR_KIF_TX_TX_STAT = 0x0002
[0x01FF]                ME_AR_P1MMU_P1_STAT = 0x0000
[0x0097]              ME_AR_DIC_CH0_CONTROL = 0x0000
[0x0098]               ME_AR_DIC_CH0_STATUS = 0x0004
[0x009D]              ME_AR_DIC_CH1_CONTROL = 0x0000
[0x009E]               ME_AR_DIC_CH1_STATUS = 0x0004
[0x0131]              ME_AR_FIC_CH0_CONTROL = 0x0000
[0x0132]               ME_AR_FIC_CH0_STATUS = 0x0004
[0x0133]              ME_AR_FIC_CH1_CONTROL = 0x0000
[0x0134]               ME_AR_FIC_CH1_STATUS = 0x0004
[0x01F1]            ME_AR_P1MMU_P1_CPU_CNTL = 0x0001
[0x0214]            ME_AR_P2MMU_P2_CPU_CNTL = 0x0001
01:29:10.559 FW[Mod 09]: AR#1
On further investigating in the module 9 which has a DFC card also , we found the source of this error
please help me in understanding this issue , whether it is a source of any upcoming potential impact or can be simply ignored
Leo Laohoo
Sounds like you need to contact TAC.
Could either be an IOS bug or a hardware failure.
My bet is on a hardware failure.
Ivan Shirshin
This are the to be informational messages with ASICs registers dump. Check the version you are running against the cosmetic DDTS CSCtn59962 - Need to suppress informational firmware registers dump.
It is fixed starting with 12.2(33)SXJ01 and does not have an harmful effect.
Simple  workaround would be changing the logging level to informational (anything other than debugging).
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Ivan:
This is present in 15.0S(1)4a, can you let me know what 15.0S train for 7600 this will be fixed in?
-aw
