error question
darego1990
Community Member
Hi guys,
http://gyazo.com/4f8036f7a355b71cd1cf0dd646d440d1.png
am i correct to say that the answer to this question is the default gateway is set incorrect? i think it should be 192.168.10.254?
cheers
Peter Paluch
Hi Craig,
You are correct, PC-1 has its default gateway configured incorrectly. It should indeed be 192.168.10.254.
Best regards,
Peter
Peter Paluch
Hi Craig,
Best regards,
Peter
thank you
fb_webuser
Level 11
Level 11
Yes, PC1 should have 192.168.10.254 as default gateway
Posted by WebUser Mario Boltek from Cisco Support Community App
fb_webuser
Level 11
Level 11
well, i guess it's for your study so... it should be in your text book or something but don't google your answers of an exam xD you'll fail later when a real life error occurs
Posted by WebUser Dennis Wieringa from Cisco Support Community App
