Error received on Cisco 6509 - Port ASIC (VISHAKHA) packet buffer failure
vd123_cisco
Hi Guys,
I have received the following error on one of our Core switches.
%PM_SCP-2-LCP_FW_ERR_INFORM: module 1 is experiencing the following error: Port ASIC (VISHAKHA) packet buffer failure detected on ports  45
%PM-4-ERR_DISABLE: packet-buffer error detected on Gi1/45, putting Gi1/45 in err-disable state
The port Gi1/45 is connected to a server and now it is in err-diabled mode.
I have tried to shut and unshut the port but received the following errors -
%CONST_DIAG-3-HM_PORT_TEST_FAIL: Module 1 TestNonDisruptiveLoopback Port(s)[45] failed. System operation continues.
%HA_EM-6-LOG: Mandatory.go_nondislp.tcl: GOLD EEM TCL policy for TestNonDisruptiveLoopback
%PM-4-ERR_DISABLE: diagnostics error detected on Gi1/45, putting Gi1/45 in err-disable state
I have checked the port and could not find any errors or drops -
DBACoreR01#sh interfaces gigabitEthernet 1/45
GigabitEthernet1/45 is down, line protocol is down (err-disabled)
  Hardware is C6k 1000Mb 802.3, address is 001a.2f60.447c (bia 001a.2f60.447c)
  Description:
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 0/255, rxload 0/255
  Keepalive set (10 sec)
  Full-duplex, Auto-speed, media type is 10/100/1000BaseT
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     110065 packets input, 13673797 bytes, 0 no buffer
     Received 16 broadcasts (12 multicasts)
     0 input errors, 0 CRC, 3 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     170240392 packets output, 15793183649 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
I have also checked the module and found a failure on port Gi 1/45
Core01#show diagnostic result module 1
Current bootup diagnostic level: minimal
Module 1: 48-port 10/100/1000 RJ45 EtherModule  SerialNo : SAL10489C30
  Overall Diagnostic Result for Module 1 : MINOR ERROR
  Diagnostic level at card bootup: minimal
  Test results: (. = Pass, F = Fail, U = Untested)
    1) TestScratchRegister -------------> .
    2) TestNonDisruptiveLoopback:
   Port  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
   Port 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
         .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  F  .  .  .
    3) TestLoopback:
    4) TestNetflowInlineRewrite:
         U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U
    5) TestAsicMemory ------------------> U
    6) TestEobcStressPing --------------> U
    7) TestFirmwareDiagStatus ----------> .
    8) TestAsicSync --------------------> .
    9) TestErrorCounterMonitor ---------> .
   10) TestLtlFpoeMemoryConsistency ----> .
CoreR01#show module
Mod Ports Card Type                              Model              Serial No.
  1   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX    SAL10689C30
  3   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX    SAL10889C3X
  5    5  Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G       SAL1550Y4ZV
  8   20  DCEF2T 4 port 40GE / 16 port 10GE      WS-X6904-40G       SAL1669C5GD
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  001a.2f60.4450 to 001a.2f60.447f   1.5   8.4(1)       15.0(1)SY3   Ok
  3  001a.2f6f.71f0 to 001a.2f6f.721f   1.5   8.4(1)       15.0(1)SY3   Ok
  5  e05f.b911.0a3b to e05f.b911.0a42   1.3   12.2(50r)SYS 15.0(1)SY3   Ok
  8  1cdf.0f9b.c05a to 1cdf.0f9b.c06d   1.0   12.2(50r)SYL 15.0(1)SY3   Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  5  Policy Feature Card 4       VS-F6K-PFC4        SAL1649TUFQ  1.2    Ok
  5  CPU Daughterboard           VS-F6K-MSFC5       SAL1646SJJ8  1.4    Ok
  8  Distributed Forwarding Card WS-F6K-DFC4-E      SAL1648T7QP  1.2    Ok
Mod  Online Diag Status
  1  Minor Error
  3  Pass
  5  Pass
  8  Pass
Could anyone please let me know what might be wrong here. is it a hardware faliure? Do I need to raise this with TAC?
Really appreciate your help.
Thank you,
Jay
No it is HW issue, though transient. Parity causes meory lockup on ASIC. On new cards this issue is fixed in manufacturing.
DDTS is only for informational purposes, there is no code fix.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Ivan Shirshin
This could be a result of a single parity (data corruption) in the SRAM on the ASIC, which is described in
    CSCsw43503    WS-X6148A-GE-TX One port will go err-disable due to VISHAKHA error
It is recommended to reseat the card and i most cases the error won't reoccur after that.
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Hi Ivan.
Thank you for the reply.
So is it a bug on the line card?
Jay
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Hi Ivan,
Sorry for the late reply.
I will let you know if the restart of the line card has fixed the issue.
Appreciate your help.
Jay
