Error while copying ios from tftp to switch
mahesh18
Level 6
Level 6
Hi all,
i am trying to copy IOS  from my TFTP server which is on laptop to cisco 3548xl  switch
my curent tftp directory on laptop is c\windows\system32
filename is c3500xl-c3h2s-mz.120-5.WC17.bin
3548XL#copy tftp:
i ran this command
3548XL#copy tftp:\\192.168.1.3_c:\windows\system32\tftp c3500xl-c3h2s-mz.120-5.WC17.bin
Address or name of remote host [192.168.1.50]? 3548xl
Source filename [\\192.168.1.3_c:\windows\system32\tftp]? c3500xl-c3h2s-mz.120-5.WC17.bin
Destination filename [c3500xl-c3h2s-mz.120-5.WC17.bin]?
Accessing tftp://3548xl/c3500xl-c3h2s-mz.120-5.WC17.bin...
%Error opening tftp://3548xl/c3500xl-c3h2s-mz.120-5.WC17.bin (Timed out)
Please help
thanks
mahesh
You only have one IOS.  You don't need to set the boot statement.  I recommend you remove any by using the command "no boot system".
15 Replies 15
Leo Laohoo
The command should be copy tftp://192.168.1.3/c3500xl-c3h2s-mz.120-5.WC17.bin flash:
Presuming that your TFTP server is pointing to the main TFTP folder.
hi
thanks for reply
i did this
#copy tftp://192.168.1.3/c3500xl-c3h2s-mz.120-5.WC17.bin flash:
Accessing tftp://192.168.1.3/c3500xl-c3h2s-mz.120-5.WC17.bin...
%Error opening tftp://192.168.1.3/c3500xl-c3h2s-mz.120-5.WC17.bin (No such file or directory)
also my tftp server window shows
current directory is c:\windows\system32
Can you do the following checks
1.Ping the switch IP address from you laptop in which TFTP is running.
2.check the tftp root directory once again, and the check the file name of the IOS.
3.Finally check weather TFTP server is running properly in your laptop.
regards
karuppu
hi,
i tried again here is result
3548XL#copy tftp://192.168.1.3/c3500xl-c3h2s-mz.120-5.WC17.bin flash:
Loading c3500xl-c3h2s-mz.120-5.WC17.bin from 192.168.1.3 (via VLAN1): !!O!!O!OOO!OO!OO!OO!OOO
%Error reading tftp://192.168.1.3/c3500xl-c3h2s-mz.120-5.WC17.bin (Transfer aborted)
Loading c3500xl-c3h2s-mz.120-5.WC17.bin from 192.168.1.3 (via VLAN1): !!O!!O!OO!OO!OO!OO!OOOOO!OOOOO!
%Error writing flash:/c3500xl-c3h2s-mz.120-5.WC17.bin (No space left on device)************************
this ios is 1.72 mb
3548XL#sh flash
Directory of flash:/
  2  -rwx     1645807   Feb 28 1993 21:32:09  c3500XL-c3h2s-mz-120.5.2-XU.bin
  3  -rwx       94674   Apr 03 2000 18:53:30  c3500XL-diag-mz-120.5-XU
  4  drwx          64   Sep 25 2006 14:40:51  html
  7  -rwx         108   Feb 28 1993 21:30:16  info
  6  -rwx         556   Feb 28 2010 22:11:24  vlan.dat
113  -rwx         108   Feb 28 1993 21:33:16  info.ver
114  -rwx        3656   Mar 04 1993 06:22:54  s2edcw2a1.txt
  8  -rwx     1811155   Sep 25 2006 14:45:03  c3500xl-c3h2s-mz.120-5.wc15.bin
10  -rwx        2588   Feb 21 2010 18:42:34  config.text
  9  -rwx         315   Sep 25 2006 14:45:37  env_vars
3612672 bytes total (49152 bytes free)
The IOS(c3500xl-c3h2s-mz.120-5.wc15.bin) you want to upgrade it is already present in the flash.
Currently there is no free space is available to upgrade.Moreover if you want to upgrade you have to delete some unncessary files , the try to upload the IOS.
regards
karuppu
He's trying to copy WC17.
Oh..sorry for the mistake.
Mahesh : try to delete the unwanted fiels in your flash.before that check the IOS version runnning in your switch.
Make the free space and try to upgrade . it should work .
regards
karuppu
i tried again
You only get "O" when either the link is slow or there's not enough flash space because something else is there.
You need to delete the following files:
Use the command "delete flash:"
Hi ,
thanks for reply
hi,
this ios is 1.72 mb
3548XL#sh flash
above shows my current flash on switch.
do you know which files i can delete?
thanks for great reply
here is what i have done
Loading c3500xl-c3h2s-mz.120-5.WC17.bin from 192.168.1.3 (via VLAN1): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 1811552 bytes]
1811552 bytes copied in 66.3 secs (27447 bytes/sec)
3548XL#sh flash
  2  -rwx     1811552   Feb 28 2010 22:25:57  c3500xl-c3h2s-mz.120-5.WC17.bin
  6  -rwx         556   Feb 28 2010 22:21:36  vlan.dat
3612672 bytes total (1694720 bytes free)
3548XL#delete v?
% Unrecognized command
3548XL#config t
Enter configuration commands, one per line.  End with CNTL/Z.
3548XL(config)#boot ?
  boothlpr            Boot Helper System Image
  buffersize          Specify the buffer size for filesystem-simulated NVRAM
  config-file         Configuration File
  enable-break        Enable Break while booting
  helper              Helper Image(s)
  helper-config-file  Helper Configuration File
  manual              Manual Boot
  system              System Image
3548XL(config)#boot sys
3548XL(config)#boot system ?
  WORD  pathlist of boot file(s) ... file1;file2;...
3548XL(config)#boot system file.bin
3548XL(config)#end
3548XL#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]n
3548XL#boot
3548XL#boot sys
3548XL#config t
3548XL(config)#boot sysa
just last step left
under config t
what command should i use
boot system c3500xl-c3h2s-mz.120-5.WC17.bin and then reload?
many thanks
Many thanks for helping me all the way.
i am all set now
take care
mahesh
Thanks for the ratings Mahesh.  Glad to be of some assistance.
