Errors in Cisco 2950 switch
govindsingh
Community Member
below is the copy of log generated on switch 2950, the access switch. The interfaces are flapping after a regular interval of time although no major input / output errors are seen and no production impact.
.Dec 7 12:02:02.042: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/1, changed state to down
.Dec 7 12:02:06.182: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/1, changed state to upcpd_reset_port_config: xcvr_reset_port_config error
.Dec 7 12:48:42.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/33, changed state to down
.Dec 7 12:48:45.875: %LINK-3-UPDOWN: Interface FastEthernet0/33, changed state
to downcpd_reset_port_config: xcvr_reset_port_config error
.Dec 7 12:48:55.707: %LINK-3-UPDOWN: Interface FastEthernet0/33, changed state
to up
.Dec 7 12:48:56.707: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/33, changed state to upcpd_reset_port_config: xcvr_reset_port_config error
.Dec 7 15:36:09.539: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/11, changed state to down
.Dec 7 15:36:14.483: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/11, changed state to upcpd_reset_port_config: xcvr_reset_port_config error
.Dec 7 15:37:04.519: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
.Dec 7 15:37:07.687: %LINK-3-UPDOWN: Interface FastEthernet0/11, changed state
to down
.Dec 7 15:37:19.891: %LINK-3-UPDOWN: Interface FastEthernet0/11, changed state
to up
.Dec 7 15:37:20.899: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
.Dec 7 15:37:45.563: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
.Dec 7 15:37:50.519: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
.Dec 7 15:46:21.230: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
.Dec 7 15:46:24.390: %LINK-3-UPDOWN: Interface FastEthernet0/11, changed state
to down
Any idea...
rgds
govind
ankbhasi
Hi Govind,
Which image version you are running on the switch?
There is a bug for these kind of error messages and the bug id is "CSCee89453"
Which is described as below
When full duplex is provisioned on the Gig SFP 10/100/1000BaseTX port, evertime
the link goes down or comes up via disconnect or shut/no shut on other side of
port (the switch it is connected to), the following error message is diplayed
and sent to the log: "cpd_reset_port_config: xcvr_reset_port_config error". The
new speed and duplex enhancements may draw more attention to these types of
bugs.
This is Integrated in: 12.1(22)EA2
So try upgrading your switch and see if that resolves the issue.
Ankur
*Pls rate helpfull post
Hi Ankur,
Thanks for your input.
following is the output of sh version. we using 12.1(19)EA1a.bin
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(19)EA1a, RELEASE SOFTWAR
(fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 09-Dec-03 00:12 by yenanh
Image text-base: 0x80010000, data-base: 0x8058A000
ROM: Bootstrap program is C2950 boot loader
Site1_TF_08 uptime is 1 year, 9 weeks, 5 days, 21 hours, 3 minutes
System restarted at 06:33:59 BST Sat Oct 1 2005
System image file is "flash:c2950-i6q4l2-mz.121-19.EA1a.bin"
cisco WS-C2950G-48-EI (RC32300) processor (revision D0) with 20809K bytes of me
ory.
Processor board ID FOC0636W03J
Last reset from system-reset
Running Enhanced Image
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0A:F4:1D:D0:40
cisco WS-C2950G-48-EI (RC32300) processor (revision D0) with 20809K bytes of mem
ory.
Motherboard assembly number: 73-7409-09
Power supply part number: 34-0965-01
Motherboard serial number: FOC06350U0M
Power supply serial number: DAB063578B7
Model revision number: D0
Motherboard revision number: A0
Model number: WS-C2950G-48-EI
System serial number: FOC0636W03J
Configuration register is 0xF
I m not able to access the bug details which you have mentioned.
switch is giving this error intermittently. no shut/no shut is being performed in other end.
I will upgrade the ios and update you for the same
regds
govind
Hi Govind,
today i ran into the same problem - and after the suggested IOS update the message is gone.
But the device still dis/- and reconnects constantly. I'll replace the NIC of the device tomorrow and check it again.
Did you had a look at the interface counters - especially the errors? ( 'mine' has a lots of errors)
Cheers
Michael
