ESXi trunk partially works
useopenid
I have an ESXi vmhost setup to trunk vlans 2, 100 and 101 to a 6509; vlan 2 is working, but neither 100 nor 101 come up.  I can't see any reason for one to work and the others not --- the only difference is the vlan id.  Native is the default vlan 1 and is not being used.
IOS (tm) c6sup2_rp Software (c6sup2_rp-JK2O3SV-M), Version 12.1(27b)E4, RELEASE SOFTWARE (fc3)
cisco WS-C6509 (R7000) processor (revision 3.0) with 227328K/34816K bytes of memory.
Processor board ID SAL0827BAAS
R7000 CPU at 300Mhz, Implementation 39, Rev 2.1, 256KB L2, 1024KB L3 Cache
# sho run
interface GigabitEthernet5/1
  switchport
  switchport trunk allowed vlan 2,100-102
  switchport mode trunk
interface GigabitEthernet5/6
switchport
switchport access vlan 101
switchport mode access
#sho int gi5/1 trunk
Port      Mode         Encapsulation  Status        Native vlan
Gi5/1     on           802.1q         trunking      1
Port      Vlans allowed on trunk
Gi5/1     2,100-102
Port      Vlans allowed and active in management domain
Gi5/1     2
Port      Vlans in spanning tree forwarding state and not pruned
Gi5/1     2
#sho int gi5/1
GigabitEthernet5/1 is up, line protocol is up (connected)
#sho int gi5/6
GigabitEthernet5/6 is up, line protocol is up (connected)
#show int vlan 2
Vlan2 is up, line protocol is up
#show int vlan 101
Vlan101 is up, line protocol is down
Do show vlan to double check and if it doesn't exist, do the following
config t
vlan xxx
exit
and confirm it with show vlan
jerry
7 Replies 7
Reza Sharifi
Hi Alan,
Usually this happens when you do not have spanning tree instance for that VLAN.
Can you do a:
sh spanning-tree vlan 100 or 102?
Reza
It's true, there's not, but that sounds like a chicken-egg problem.  Though, actually, ESXi specifically doesn't do spanning tree because their virtual switches don't talk to each other, preventing loops (according to their docs).  Also, vlan2 is working, and I would expect it to have the same problem as the other vlans.
I did try adding:
switchport nonegotiate
spanning-tree portfast trunk
which I saw used on another website discussing esx trunking, but that doesn't help.  My understanding of "portfast" is that that basically shuts off spanning tree and just forwards regardless.
#sho spanning-tree vlan 1-4094
VLAN0001
  Spanning tree enabled protocol rstp
  Root ID    Priority    32768
             Address     0011.5d6f.c001
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32768
             Aging Time 300
Interface        Role Sts Cost      Prio.Nbr Type
Gi3/7            Desg FWD 4         128.135  P2p
VLAN0002
             Address     0011.5d6f.c002
             Aging Time 300
Gi3/16           Desg FWD 4         128.144  P2p
Gi5/1            Desg FWD 4         128.257  Edge P2p
Gi6/4            Desg FWD 4         128.324  P2p
(vlan 101 does not show up at all in this output)
#sho spanning-tree vlan 101
Spanning tree instance(s) for vlan 101 does not exist.
config t
vlan xxx
exit
jerry
Progress!  I had defined the interface to get an ip address for testing, but not the vlan itself:
Gi5/1     2,100-102
Gi5/1     2,101
Gi5/1     2,101
#sho vlan name VLAN0101
VLAN Name                             Status    Ports
101  VLAN0101                         active    Gi3/7, Gi5/1, Gi5/6
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
101  enet  100101     1500  -      -      -        -    -        0      0
Remote SPAN VLAN
Disabled
Primary Secondary Type              Ports
# sho run
interface Vlan101
description ServerNet NG
ip address 172.20.19.253 255.255.252.0
no ip redirects
hold-queue 2048 in
hold-queue 2048 out
#sho int vlan101
Vlan101 is up, line protocol is up
Still not pinging though, not even arping on the guest, but that could be esxi issues --- "show int vlan101" shows packets output but nothing input.
Thanks for this much though!
Check your native VLAN under ESXi, i think vmware is using something like VLAN0 as native, don't remember that 100%.
jerry
I don't why the native vlan would matter (assuming it doesn't conflict with a tagged vlan), as I have all the virtual nics in tagged port groups (save for a management lan on a different physical interface).
I think VMware uses VLAN 0 for all untagged frames (native vlan) and I believe you have to configure service console port group with VLAN id 0.
