Ether channel interface suspended mode
meiyappan
Connection between our core switch to access switch is showing suspended for etherchannel interface
interface GigabitEthernet1/0/2
  switchport mode trunk
 channel-group 2 mode on
end
interface GigabitEthernet1/0/1
end
interface Port-channel2
GigabitEthernet1/0/1 is up, line protocol is down (suspended)
    MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
GigabitEthernet1/0/2 is up, line protocol is up (connected)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s, media type is 10/100/1000Base
Logs:
TX%EC-5-CANNOT_BUNDLE2: Gi1/0/1 is not compatible with Gi1/0/2 and will be suspended (speed of Gi1/0/1 is 100M, Gi1/0/2 is 1000M)
why the speed is varying but i was configured as auto  , Kindly suggest
Gi1/0/2    connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi1/0/1    suspended    trunk      a-full  a-100 10/100/1000BaseTX
Ok.  Thanks for the output.
Output tells me you've got a cable problem at the remote end of Gi 1/0/1.  Maybe the patch cable or could be the punch block.
If you want GigabitEthernet speed then Pairs A, B and D must be NORMAL.
7 Replies 7
Leo Laohoo
Make sense.  Look at the speed of both ports.  They are not the same.  And this is why Gi1/0/1 is suspended.
Gi 1/0/1 could potentially have a faulty cable.  You could try running a TDR to determine.
1.  Command:  test cable tdr interface Gi 1/0/1;
2.  Wait for approximately 5 to 7 seconds;
3.  Command:  sh cable tdr interface Gi 1/0/1;
4.  Post the output to #3.
logs :
Interface Speed Local pair Pair length        Remote pair Pair status
Gi1/0/1   100M  Pair A     36   +/- 0  meters N/A         Normal
                Pair B     37   +/- 1  meters N/A         Short/Crosstalk
                Pair C     74   +/- 0  meters N/A         Normal
                Pair D     37   +/- 1  meters N/A         Short/Crosstalk
thank you leo  let me check
there was issue in patch panel port is not supporting  the speed, after changing to other port  its fine.
thanks
Gi0/45 100M Pair A 25 +/- 4 meters Pair A Normal
Pair B 4 +/- 4 meters Pair B Open
Pair C 24 +/- 4 meters Pair C Normal
Pair D 25 +/- 4 meters Pair D Normal
2nd switch
Gi0/43 100M Pair A 25 +/- 4 meters Pair B Normal
Pair B 20 +/- 4 meters Pair A Open
Pair C 25 +/- 4 meters Pair C Normal
TYFANAN
Hi all community fellows. Just to share my experience and how I solved the problem. My situation looks like that - a Cisco UCS C240 M4S2 server connected with four ports to two Cisco 3850 switches in a stack. There are two ports connected to each switch in a stack. All four ports on the 3850 are in a port channel. After some maintenance in the rack the issue - "%ETC-5-CANNOT_BUNDLE2: Gi1/1/1 is not compatible with Gi1/1/2 and will be suspended (speed of Gi1/1/1 is 100M, Gi1/1/2 is 1000M)" appears on 3850. Port channel went down and I lost connectivity between the server and the switch. Reading the posts above I try to check all the connections - cables, jacks and inserts connecting the devices. It appears to be one of the cables with interrupted wire 5, so making possible only 100 M of speed for this connection. Replacing the faulty wire fix the problem for me. So check all physical elements before experiment with any settings. This is it. I solved my problem. Hope to help someone this way.
