Ether-channel problem between two different vendors
hamzashahid
hi this is hamza
i m making ether-channel between two different switches first one is Cisco catalyst 3560 24PS and on other side fortiswitch 14D i have plugged two backbones on port 21 and 22 on Cisco side and on port 1 and 24 on fortiswitch side
fortiswitch is using active mode while cisco is using passive mode
as u can see the configuration
the problem is when i configure ether-channel cisco switch shutdown port fa0/21 and if i plug into on another port it gets back up, it seems when i make-up LACP protocol that backbone doesn't work
both sides have same duplex and speed and both backbones are same in every form
Current configuration : 1739 bytes
version 12.2
service config
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Switch
enable secret 5 $1$3E0V$UTj9qgb9OFltI28QZpi1p0
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface Port-channel1
switchport mode trunk
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
switchport nonegotiate
no keepalive
speed 100
duplex full
channel-group 1 mode passive
channel-protocol lacp
interface FastEthernet0/22
speed 100
duplex full
interface FastEthernet0/23
speed 100
duplex full
interface FastEthernet0/24
speed 100
duplex full
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address dhcp
ip classless
ip http server
control-plane
line con 0
line vty 0 4
password 7 045A0F0B062F6C1C584B
login
line vty 5 15
login
end
i tried without switchport nonegotiate but that still doesn't work out
hope u understand that problem
Best Regards:
HAMZA SHAHID
The switchport trunk encapsulation dot1Q command is an older command for older IOS because in the past Cisco devices supported both ISL and dot1q. If you are running a new version of IOS, you don't need this command. All you need is:
Reza Sharifi
If LACP does not work try it mode on.Example:
speed 100
duplex full
channel-group 1 mode on
And test again.
yes i will try this one , but i did not understand why do we need to use switchport trunk encapsulation dot1Q instead only using switchport mode trunk  i never use this encapsulation in packet tracer if this is necessary to use it with switchport mode trunk then y did not Cisco recommend it while training of CCNA
can u please guide me that switches in packet tracer performing layer 3 switches or layer 2 i can olny understand of word between L3 and L2 is the difference of ip assigning is it true or their is something else
Best Regards:
HAMZA SHAHID
