Ether Channel
saranbhatia
I have a PC connected with a cisco 2900 series switch.This switch is cascaded with another switch(same series),which is further connected witha PC.
I have cascaded the two swtches through two cross cables at port 2 and 3 respectively on both switches.My machines are connected to port 1 on both machines.
My question is--
I need to make an ether channel for load balancing,but when i configure on both switches,i am getting RTOs when i m pinging from one machine to another.
can anybody tell me about the configuration of the ether channel??i dont know where i am going wrong...
mohammedmahmoud
Level 11
Level 11
Can you please past your configuration.
HTH,
Mohammed Mahmoud.
Hi Sarabhatia,
the configuration of 2900 series etherchannel as follows...
interface fas 0/1
channel-group 1 mode on
interface fas 0/2
once after issuing this command, a port-channel interface is been formed
interface port-channel 1
configure the same on the other switches also.
ofcourse it does a load balancing also, which means even if 1 interface shuts down or the cable failure has happend,u will not feel as if the connectivity has lost, bcoz the interface the data will still b flowing. also by doing this u get 2Gbps
