Etherchannel -1 port in Pd state in 2950 switch
mahesh18
Level 6
Level 6
Hi all,
I have 2 2950 switches where there gi0/ 1 and gi 0/2 are connected with each other and performing the trunk.
sh int trunk
Port        Mode         Encapsulation  Status        Native vlan
Po1         on           802.1q         trunking      1
Port      Vlans allowed on trunk
Po1         1-4094
Port        Vlans allowed and active in management domain
Po1         1
Port        Vlans in spanning tree forwarding state and not pruned
Po1         1
Today i created the etherchannel  with the trunk ports gi01 and 02 of both switches.
2950T#sh etherchannel summ
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        u - unsuitable for bundling
        U - in use      f - failed to allocate aggregator
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)          -        Gi0/1(Pd)   Gi0/2(P)
My question is why port gi0/1 shows as Pd---default port  ?
is this due to spann     tree loop?
many thnaks
pbvijay77
  This is used for transmit protocols like STP,and Multicast.... in the redunant link
here is the link for your reference
http://www.cisco.com/application/pdf/paws/12023/4.pdf
Thank you
Vijay
Hi Vijay,
Thanks for reply so the port in other states gi0/1 on both switches is it in blocking state on both ends or blocking state on 1 end only?
Ganesh Hariharan
Hi all,
sh int trunk
Po1         1-4094
Po1         1
Po1         1
        d - default port
many thnaks
Genrally Catalyst 2900XL/3500XL switches maintain a notion of a default port on which to transmit traffic, such as Spanning Tree Protocol (STP), multicasts, and unknown unicasts.
Check out the below link for further information
http://www.cisco.mn/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
Hope to help
If helpful do rate the post
Ganesh.H
Giuseppe Larosa
Hello Mahesh,
you will find out that all traffic uses only one port of the port-channel, this platform C2950 implements port channels in this way.
So you get redundancy but only one link will be used.
We had even opened a Cisco TAC SR for this reason.
Hope to help
Giuseppe
