Etherchannel - Layer 2 or 3
Freihafener
Hey there!
We are about to connect to another building with different IP ranges using an airlaser and an microwave link. We have two Cisco 3560X providing connection to the different LANs of the two buildings. Between the two Ciscos we use a transfer network and VLAN with an own IP Range, so the two 3560X have to route the different IP ranges. Both switches have an IP address in the transfer VLAN used as next hop for routing.
Our plan is to configure airlaser and microwave as an Etherchannel. Question is if we should use a layer 2 or a layer 3 etherchannel? What is the difference? Wouldn´t layer 2 be faster than layer 3? Will layer 2 cause trouble with routing or load balancing?
Would be thankful for a quick answer!
Hi Frieh ,
              Though u have used this VLAN on both switch and u made your port access Layer , It same like L3 etherchannel , instead defining ip address on interface port-channel 1 ,you have defined on L3 SVI and made your switch port to act like L2 port ,  it will pass all traffic via access link , though u have given routing for this VLAN IP address . This is good one on layer 2 switch .
         If you have used your switchport as L3 port it avoid vlan databse ,STP , which only carries Pagp protocol or LACP internally . If its trunk port between 2 switch only option is  its can be used only as L2 port on your both switch  . You cannot define L3 ether channel over there .
san
HTH Regards Santhosh Saravanan
9 Replies 9
sansarav720e
Hi Freih ,
              As you said ur 2 building switches has 2 differnet vlan which doing routing based on your routing table , In this senario its better to have L3 ether channel , you can have L3 Ether channel defined on your switch .
config on both switch
interface portchannel 1
no switch port
ip address x.x.x.x 255.255.255.252
interface range fastethernet 0/23-24
channel-protocol pagp
channel-group 1 mode auto
L2 ether channel can be used on trunk port to avoid STP looping .
San
Here is the link for l3 ether channel configuration
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.1_19_ea1/configuration/guide/swethchl.html
san
Hi San,
thanks for your quick answer. But why is it better to use a layer 3 etherchannel? Because we already have to use routing between the different ip ranges?
BTW for information the config of one of our switches:
interface Port-channel1
switchport access vlan 100
switchport mode access
flowcontrol receive desired
spanning-tree portfast
interface GigabitEthernet0/1
description Po1 Airlaser
speed 100
duplex full
channel-group 1 mode desirable
VLAN 100 has an IP address on both siwtches for routing purposes.
it works, but now I think about configurationg a layer 3 etherchannel...
Hi Frieh ,
san
hello
Here is mine
CORE#sh interfaces port-channel 9 status
Port      Name               Status       Vlan       Duplex  Speed Type
Po10      here-to-B     connected    trunk     a-full a-1000
CORE#sh interfaces port-channel 9 etherchannel
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
0     00     Gi1/0/11 On                 0
  0     00     Gi2/0/11 On                 0
interface Port-channel9
description from-here-to-B
switchport trunk native vlan Y
switchport trunk allowed vlan Y,XX,XX,XX,XX,XX,XX
switchport mode trunk
interface GigabitEthernet1/0/11
channel-group 10 mode on
interface GigabitEthernet2/0/11
and in the other side the same!
Tell me if it works
Good Luck
Hello ro,
you configured a trunk between your switches. I chose a switchport because of the management interfaces of the microwave link switches.While the connection is transparent and looks like a direct connection from cisco to cisco switch, the mircrowave link management is embedded in the connection.
This management IP has no VLAN configuration, so I guess it would not be accessible if I configure a trunk - but I also have to say that this is my first configuration of microwave link hardware.
FH
Hi San,
right, the switches have to work on Layer3 (=routing) when passing traffic from one switch VLAN interface to the other. So in my case I would guess that it is all the same if I configure a layer 2 oder layer 3 etherchannel. I suppose that STP and a VLAN database would not affect transfer negatively.
To use a layer 3 channel I would have to configure "no switchport" corresponding to the link you left here (thanks for that). But if it is all the same - I can save the time!?
At the end etherchannel works - but you hardly get access to the management of the connecting devices in the channel. And because of the devices the link between the ciscos do not go down if the laser / microwave is broken.
That is not really handy - but thanks for your posts!
I configured L3 on both switches but i m confused how am i supposed to assign "port-channel IP address" on PC in order to ping other side? Or do not required to so anything after creating L3 etherchannel?
