03-28-2012 07:39 AM - edited 03-07-2019 05:50 AM
On a WS-C3750X it tooks 1 minute after connecting a port to change the status from LINK-3-UPDOWN "up" to LINEPROTO-5-UPDOWN "up"
Mar 27 16:25:37 192.168.1.144 788: *Mar 8 00:30:48.032: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up Mar 27 16:26:38 192.168.1.144 790: *Mar 8 00:31:49.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to upMar 27 16:25:54 192.168.1.144 789: *Mar 8 00:31:05.086: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/1, changed state to up Mar 27 16:26:56 192.168.1.144 791: *Mar 8 00:32:06.583: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/1, changed state to up
The ports are configured like that:
interface GigabitEthernet1/0/1
switchport access vlan 27switchport mode access
spanning-tree portfastspanning-tree bpdufilter enable
channel-group 1 mode passive !interface GigabitEthernet2/0/1
channel-group 1 mode passive!
interface Port-channel1
end
The server which is connected has nothing special configured...
Does anyone have an idea why this takes so long?
Thanks!
Cheers,
Tobias
03-28-2012 08:23 AM
Is LACP also configured on the server side?
Also, usually the switch runs in active mode and server is passive mode
channel-group 1 mode active
Can you test again?
03-29-2012 12:06 AM
No, LACP is not configured on the server during boot/dhcp/pxe. It's configured later on in the Linux OS (and this works, but also takes 60 seconds between link up and protocol up). I've changed to mode active, but that did not change anything. I had mode passive because I read somewhere that dhcp/pxe does only work with this mode. But after changing to active it still works, but it takes a long time to get the lease because of the mentioned problem...
Cheers,
Tobias
This is how it looks when Linux is booting up and configure the links:
Mar 29 09:02:10 192.168.1.144 1655: *Mar 9 17:07:27.138: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to down
Mar 29 09:02:11 192.168.1.144 1656: *Mar 9 17:07:27.364: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/1, changed state to down
Mar 29 09:02:13 192.168.1.144 1657: *Mar 9 17:07:29.520: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
Mar 29 09:02:31 192.168.1.144 1658: *Mar 9 17:07:47.748: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/1, changed state to upMar 29 09:03:09 192.168.1.144 1659: *Mar 9 17:08:25.346: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up
Mar 29 09:03:10 192.168.1.144 1660: *Mar 9 17:08:26.344: %LINK-3-UPDOWN: Interface Port-channel1, changed state to upMar 29 09:03:11 192.168.1.144 1661: *Mar 9 17:08:27.225: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/1, changed state to up
Mar 29 09:03:11 192.168.1.144 1662: *Mar 9 17:08:27.351: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to up
