09-19-2007 09:20 PM - edited 03-05-2019 06:35 PM
Is it possible to apply ether-channel/LACP on 2 pair of stacked switches? (one link is on the other switch and other link in another switch)
09-19-2007 09:34 PM
Hi Alex,
See if this helps
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12240se/scg1/swethchl.htm#wp1376062
Ankur
*Pls rate all helpfull post
09-21-2007 03:38 AM
Hi Alex,
Yes, this is possible, just make sure the channel is using LCAP by setting the channel-group mode to active.
Example:
interface GigabitEthernet1/0/1
switchport mode trunk
channel-group 1 mode active
interface GigabitEthernet2/0/1
HTH,
Leo
