EtherSwitch Module Configuration on 2921
refram
Level 3
Level 3
I have a 2921 ISR using IOS 15.3(2)T.  I'm trying to configure an installed SM-ES3G-24-P.  From what I've read, putting the module into the router automatically creates a couple of gigabit ports, one of which I'm supposed to address and use as my hop-off point to get into the switch and configure it.  However, there are no virtual ports there, just the 3 physical gigabit ports.  What might I have done wrong?
InayathUlla Sharieff
Refram,
Use this configuration guide to get started -
http://www.cisco.com/en/US/customer/docs/routers/access/interfaces/software/feature/guide/eesm_sw.html#wp1919696
Answer is given in step13:
Step 13
control+shift+6 x
Example:
Switch#control+shift+6 x
Returns you to the router console while keeping the console session to the switch
Procedure:
Usectrl+shift+6+ X and clear the line 1/0 as follow
switch# press ctrl shift 6 x
Router#sh session
          #Clear line 1/0
Inayath
*Plz rate this post if usefull and mark the thread as answered.
refram
Level 3
Level 3
Turned out I needed to put the module into the other slot in the router.  When I did so, the virutal ports were created and everything was just fine.
Thanks for posting back to the forum and clarifying what the issue was. It is a bit unexpected to have dependencies that a Service Module will function in a particular slot but not in the other slot. So perhaps your post will save some of the forum participants from some confusion.
Rick
Rick
