Exam subnetting question
mahesh18
Level 6
Level 6
this is Exam question
can someone explain me what is correct answer for this
mant thanks
mahesh
3 Accepted Solutions
adamclarkuk_2
Level 4
Level 4
Link A just needs 2 IP's one for each router
Link A = 172.16.3.0/30
Usable 172.16.3.1 - 172.16.3.2
172.16.3.40/30 falls into the already used 172.16.3.32/27 network.
Network A needs 120 address, so the closest match here is a /25
Network A = 172.16.3.128/25
Usable 172.16.3.129 - 172.16.3.254
The other 2 /26 networks do not provide enough hosts as a /26 only gives 62 usable IP's.
Richard Burts
Mahesh
From this question network A has 120 hosts. A subnet with /26 mask will support only 62 hosts. So network A needs a /25 mask which will support 126 hosts. So "B" is one of the answers. For link A the correct answer is "D" because the choice in E overlaps the network for Marketing in the drawing.
Rick
Rick
Harold Ritter
Mahesh,
Network A requires at least a /25 to accommodate 120 hosts, which makes B the only option.
As far as link A is concerned, the answer could be D or E, but since D is contiguous with the 3 other links, I would say D is the logical one to pick.
6 Replies 6
adamclarkuk_2
Level 4
Level 4
Richard Burts
Mahesh
Rick
Rick
Harold Ritter
Mahesh,
Oops. Rick is correct. E is not an option. I check the network map too quickly.
Hi Harold
Does E not fall into the network range hanging off Marketing 172.16.3.32/27 :-s
hi
Many thanks to all again for solving my
questions
sincerely
mahesh
