Example configs for Stacking WS-C3850-48P
Not applicable
Would like to see example configurations ( What configs look like ) when stacking 3 3850 switches.
G
Reza Sharifi
Have a look at the config guide for instructions:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/ha_stack_manager/configuration_guide/b_hastck_3se_3850_cg/b_hastck_3se_3850_cg_chapter_010.html
Joseph W. Doherty
When you stack switches, generally the only significant config difference is you have more ports you can configure.  Adding a stack member, config wise, is much like adding a port line card to a chassis.
