extended ACL not maching statements
Adam_S
Hi Everyone,
Looking for some help in regards to an extended ACL. I am trying to block access to all internal subnets from my 80.80.80.0 network, but permit access to from my internal subnets to modem (80.80.80.2). I've configured an applied an ACL but the statement is never matched and access to the modem is denied. Any help/suggestions appreciated.
ip access-list extended EDGE_SECURITY
permit ip 172.16.0.0 0.0.0.255 80.80.80.2 0.0.0.0
deny ip 80.80.80.0 0.0.0.255 any
permit ip any any
Amel#show ip access-lists
Extended IP access list EDGE_SECURITY
    10 permit ip 172.16.0.0 0.0.0.255 host 80.80.80.2
    20 deny ip 80.80.80.0 0.0.0.255 any (1221 matches)
    30 permit ip any any (17934 matches)
Amel#show run
Building configuration...
Current configuration : 8270 bytes
version 12.4
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
hostname Amel
boot-start-marker
boot system flash:c2800nm-advipservicesk9-mz.124-15.T9.bin
boot-end-marker
logging buffered 4096 informational
enable secret 5 $1$ZFe8$g4l2RoRNxgxEw.lD.QLYY0
no aaa new-model
clock timezone AEST 10
clock summer-time AEDT recurring last Sun Oct 2:00 last Sun Mar 3:00
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1 192.168.0.100
ip dhcp excluded-address 10.212.0.1 10.212.0.100
ip dhcp excluded-address 10.12.0.1 10.12.0.100
ip dhcp excluded-address 10.112.0.1 10.112.0.100
ip dhcp excluded-address 10.213.0.1 10.213.0.100
ip dhcp excluded-address 172.16.0.1 172.16.0.100
ip dhcp excluded-address 192.168.20.1 192.168.20.100
ip dhcp pool VLAN10_MANAGEMENT
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   lease 24
ip dhcp pool VLAN212_W_DATA
   network 10.212.0.0 255.255.255.0
   default-router 10.212.0.1
   dns-server 8.8.8.8
   lease 24
ip dhcp pool VLAN213_Wireless_Voice
   network 10.213.0.0 255.255.255.0
   default-router 10.213.0.1
   dns-server 8.8.8.8
   lease 24
ip dhcp pool VLAN12_DATA
   network 10.12.0.0 255.255.255.0
   default-router 10.12.0.1
   dns-server 8.8.8.8
   lease 24
ip dhcp pool VLAN16_WIRELESS_N
   network 172.16.0.0 255.255.255.0
   default-router 172.16.0.1
   dns-server 8.8.8.8
   lease 24
ip dhcp pool VLAN112_Voice
   network 10.112.0.0 255.255.255.0
   default-router 10.112.0.1
   dns-server 8.8.8.8
   lease 24
no ip domain lookup
ip name-server 8.8.8.8
ip multicast-routing
voice-card 0
 no dspfarm
vtp domain home
vtp mode transparent
archive
 log config
  hidekeys
vlan 10
 name Managemet
vlan 12
 name DataVlan
vlan 16
 name WIRELESS_N
vlan 17
 name Home_Automation
vlan 20
 name Guest
vlan 112
 name VoiceVlan
vlan 212
 name Wireless
vlan 213
 name WirelessPhones
interface Loopback0
 ip address 10.255.255.255 255.255.255.255
 ip broadcast-address 0.0.0.0
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.255.255.255
interface FastEthernet0/0
 description Internet
 ip address 80.80.80.1 255.255.255.0
 ip access-group EDGE_SECURITY in
 ip nat outside
 ip virtual-reassembly
 duplex full
 speed 100
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface FastEthernet0/1/0
 switchport trunk native vlan 10
 switchport mode trunk
 duplex full
 speed 100
 spanning-tree portfast
interface FastEthernet0/1/1
 duplex full
 speed 100
interface FastEthernet0/1/2
 description AP1
 duplex full
 speed 100
interface FastEthernet0/1/3
 switchport access vlan 16
 duplex full
 speed 100
interface FastEthernet0/1/4
 description Alarm
 switchport access vlan 17
 duplex full
 speed 100
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
 duplex full
 speed 100
interface FastEthernet0/1/8
 duplex full
 speed 100
interface Serial0/3/0
 no ip address
 encapsulation frame-relay
 clock rate 2000000
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 description Management
 ip address 192.168.0.1 255.255.255.0
interface Vlan12
 description Data
 ip address 10.12.0.1 255.255.255.0
 ip nat inside
interface Vlan16
 description Wirless_N
 ip address 172.16.0.1 255.255.255.0
 ip helper-address 10.12.0.2
 ip directed-broadcast
 ip nat inside
interface Vlan17
 description Home_Automation
 ip address 172.17.0.1 255.255.255.0
 ip nat inside
interface Vlan112
 description Voice
 ip address 10.112.0.1 255.255.255.0
interface Vlan212
 description Wireless_G
 ip address 10.212.0.1 255.255.255.0
 ip nat inside
interface Vlan213
 description Wireless_Voice
 ip address 10.213.0.1 255.255.255.0
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 80.80.80.2
no ip http server
no ip http secure-server
ip nat inside source list NAT-ACL interface FastEthernet0/0 overload
ip nat inside source static tcp 10.12.0.2 8000 80.80.80.1 8000 extendable
ip nat inside source static udp 10.12.0.2 8000 80.80.80.1 8000 extendable
ip nat inside source static tcp 172.17.0.2 10000 80.80.80.1 10000 extendable
ip nat inside source static udp 172.17.0.2 10000 80.80.80.1 10000 extendable
ip nat inside source static tcp 172.17.0.2 10001 80.80.80.1 10001 extendable
ip nat inside source static udp 172.17.0.2 10001 80.80.80.1 10001 extendable
 permit ip any any
ip access-list extended NAT-ACL
 permit ip 10.12.0.0 0.0.0.255 any
 permit ip 10.112.0.0 0.0.0.255 any
 permit ip 10.212.0.0 0.0.0.255 any
 permit ip 10.213.0.0 0.0.0.255 any
 permit ip 172.17.0.0 0.0.0.255 any
 permit ip 172.16.0.0 0.0.0.255 any
tftp-server flash:/c7921/APPS-1.0.4.SBN alias APPS-1.0.4.SBN
tftp-server flash:/c7921/CP7921G-1.0.4.LOADS alias CP7921G-1.0.4.LOADS
tftp-server flash:/c7921/GUI-1.0.4.SBN alias GUI-1.0.4.SBN
tftp-server flash:/c7921/SYS-1.0.4.SBN alias SYS-1.0.4.SBN
tftp-server flash:/c7921/TNUX-1.0.4.SBN alias TNUX-1.0.4.SBN
tftp-server flash:/c7921/TNUXR-1.0.4.SBN alias TNUXR-1.0.4.SBN
tftp-server flash:/c7921/WLAN-1.0.4.SBN alias WLAN-1.0.4.SBN
tftp-server flash:/c7911new/c7911/apps11.8-3-2-27.sbn alias apps11.8-3-2-27.sbn
tftp-server flash:/c7911new/c7911/cnu11.8-3-2-27.sbn alias cnu11.8-3-2-27.sbn
tftp-server flash:/c7911new/c7911/cvm11sccp.8-3-2-27.sbn alias cvm11sccp.8-3-2-27.sbn
tftp-server flash:/c7911new/c7911/dsp11.8-3-2-27.sbn alias dsp11.8-3-2-27.sbn
tftp-server flash:/c7911new/c7911/jar11sccp.8-3-2-27.sbn alias jar11sccp.8-3-2-27.sbn
tftp-server flash:/c7911new/c7911/SCCP11.8-3-3S.loads alias SCCP11.8-3-3S.loads
tftp-server flash:/c7911new/c7911/term06.default.loads alias term06.default.loads
tftp-server flash:/c7911new/c7911/term11.default.loads alias term11.default.loads
control-plane
voice-port 0/2/0
voice-port 0/2/1
ccm-manager redundant-host 10.12.0.21
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold bind Loopback0
ccm-manager config server 10.12.0.21
ccm-manager config
mgcp
mgcp call-agent 10.12.0.25 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp behavior g729-variants static-pt
mgcp profile default
dial-peer voice 999020 pots
 service mgcpapp
 port 0/2/0
dial-peer voice 999021 pots
 service mgcpapp
 port 0/2/1
dial-peer voice 999030 pots
 service mgcpapp
dial-peer voice 1 voip
 destination-pattern 10924
 session target ipv4:10.255.255.255
call-manager-fallback
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address 10.255.255.255 port 2000
 max-ephones 5
 max-dn 5
line con 0
line aux 0
line vty 0 4
 exec-timeout 0 0
 password 7 10620C0A111606
 login
line vty 5
 exec-timeout 0 0
 password 7 00071A150754
 login
scheduler allocate 20000 1000
ntp clock-period 17180094
ntp update-calendar
ntp server 216.239.38.15
Philip D'Ath
You are matching traffic coming into the routing device - not going out.  To match that way you would need to do:
permit ip 80.80.80.2 0.0.0.0 172.16.0.0 0.0.0.255
permit ip any any
5 Replies 5
Philip D'Ath
permit ip any any
Thanks for the suggestion. I applied the ACL (tried both ip access group
EDGE_SECURITY in and out), but still no love.
10 permit ip host 80.80.80.2 172.16.0.0 0.0.0.255
20 deny ip 80.80.80.0 0.0.0.255 any (6 matches)
30 permit ip any any (18 matches)
if any further info is required please let me know.
One thing to check:
interface Vlan16
ip nat inside
Are you trying it from a device connected to wireless device which gets its IP address from 172.16.0.0/24 block?
HTH,
Meheretab
HTH,
Meheretab
Yes i am connected to that subnet:
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Centrino(R) Wireless-N 135
Physical Address. . . . . . . . . : 0C-D2-92-45-1D-9D
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 172.16.0.104(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Thursday, 21 September 2017 1:21:00
PM
Lease Expires . . . . . . . . . . : Sunday, 15 October 2017 1:21:02 PM
Default Gateway . . . . . . . . . : 172.16.0.1
DHCP Server . . . . . . . . . . . : 172.16.0.1
DNS Servers . . . . . . . . . . . : 8.8.8.8
NetBIOS over Tcpip. . . . . . . . : Enabled
A good link for NAT Order of Operation:
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/6209-5.html
Since you have enabled NAT (PAT), whenever traffic comes from the Modem it will be checked with the INPUT ACL before NAT translation. As a result, you will not see traffic match on the first line of the ACL.
One way to solve it is to apply Outbound ACL on the interface connected to the  172.16.0.0/24 network.
HTH,
Meheretab
HTH,
Meheretab
