01-17-2024 05:08 PM
Hi there
I set the Access map and Access list in the C9410 model.
This is part of the settings.
vlan-access-map vacl12 6
match ip address vlan12-emaster
action forward
vlan-access-map vacl12 10
action drop
ip access-list extended vlan12-emaster
permit ip 10.10.64.0 0.0.7.255 host 10.10.101.61
permit ip 10.10.64.0 0.0.7.255 host 10.10.101.62
permit ip 10.10.64.0 0.0.7.255 host 10.10.101.63
permit ip 10.10.64.0 0.0.7.255 host 10.10.101.64
permit ip 10.10.64.0 0.0.7.255 host 10.10.101.65
permit ip 10.10.64.0 0.0.7.255 host 10.10.62.21
permit ip 10.10.64.0 0.0.7.255 host 10.10.62.22
permit ip 10.10.64.0 0.0.7.255 host 10.10.62.23
permit ip 10.10.64.0 0.0.7.255 host 10.10.62.24
permit ip 10.10.64.0 0.0.7.255 host 10.10.62.25
permit ip 10.10.64.0 0.0.7.255 10.10.56.0 0.0.7.255
permit ip 10.10.64.0 0.0.7.255 10.10.96.0 0.0.7.255
Despite the permit settings set in the same forward policy, IPs 10.10.101.61~65 cannot remotely connect to other PCs. However, 10.10.62.21~25 is being remotely connected normally.
To check the policy, if the permit policy of the drop policy, permit ip 10.10.64.0 0.0.7.255 10.10.96.0 0.0.7.255, is deleted, IPs 10.10.101.61~65 will be able to remotely access other PCs normally.
Even after deleting and resetting the forward settings, the symptom is the same. What is the problem?
01-17-2024 08:32 PM
switch1(config)#vlan filter Mapping vlan-list 1
I dont see vlan filter command?
MHM
01-17-2024 08:37 PM
I already added vlan filter command like this
vlan filter vacl12 vlan-list 12
01-17-2024 08:41 PM
The history is as follows:
First, I was using the forward policy for the 101.0 IP, and it worked well without any problems.
Later, due to an office move, I added a policy for the 62.0 IP to forward, and this also worked well.
However, after the office was changed again and an attempt was made to use the 101.0 IP, remote access was not possible.
01-17-2024 09:59 PM
Ok' maybe the acl hung in some point.
You have two line start with seq 6
Add new line let say seq 1 for permit traffic and seq 2 for deny other
If it work remove seq 6 and 10.
MHM
