extended vlan question
Brent Rockburn
Level 2
Level 2
This is probably going to be something simple but does anyone why this is happening
sw(config-vlan)#exit
% Applying VLAN changes may take few minutes.  Please wait...
%Failed to commit extended VLAN(s) changes.
BR
cadet alain
To configure extended VLAN your switch must be in vtp transparent mode and the default is Server mode.
So first change VTP mode and then create extended VLANs and apply changes.
Regards.
Alain.
Leo Laohoo
Is this coming from a 2940/2950/2955 switch?  If yes, that what IOS are you running.  I believe you need to run at least EA5 to have extended VLAN.
