Extremely high Drop count and buffer misses at C6800IA interface ports
hsticher
Is there any possibility  to reduce these tremendous drops?
Short network diagram:
LAN----C6880-X----FEX101----Client      >>> High drop rate at all Gi-Interfaces
LAN----C4506---Client  >>> No Drops
FEX-101#sh ver
Cisco IOS Software, C6800IA Software (C6800IA-UNIVERSALK9-M), Version 15.2(3a)E, RELEASE SOFTWARE (fc5)
FEX-101#sh int gi2/0/32
GigabitEthernet2/0/32 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 8480.2d28.9320 (bia 8480.2d28.9320)
  MTU 9216 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 4d01h
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 72513
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     1755463 packets input, 118899318 bytes, 0 no buffer
     Received 1363 broadcasts (566 multicasts)
     0 watchdog, 566 multicast, 0 pause input
     6739923 packets output, 9237933002 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
FEX-101#sh buffer
Interface buffer pools:
RxQ15 buffers, 2176 bytes (total 4, permanent 4):
     0 in free list (0 min, 4 max allowed)
     17075930 hits, 17075926 misses
FEX-101#show controllers ethernet-controller port-asic statistics
 Switch 3, PortASIC 0 Statistics
         0 TxBufferFull Drop Count
         0 TxBufferFrameDesc BadCrc16
         0 TxBuffer Bandwidth Drop Cou
         0 TxQueue Bandwidth Drop Coun
         0 TxQueue Missed Drop Statist
         0 RxBuffer Drop DestIndex Cou
         0 SneakQueue Drop Count
         0 Learning Queue Overflow Fra
         0 TxBufferFrameDesc BadCrc16            0 Rx NP Packet Count0
         0 RxBuffer Drop DestIndex Cou   167242730 Rx NP Packet Count1
         0 Sup Queue 0 Drop Frames               0 Sup Queue 8 Drop Frames
         0 Sup Queue 1 Drop Frames               0 Sup Queue 9 Drop Frames
         0 Sup Queue 2 Drop Frames               0 Sup Queue 10 Drop Frames
         0 Sup Queue 3 Drop Frames               0 Sup Queue 11 Drop Frames
         0 Sup Queue 4 Drop Frames           91781 Sup Queue 12 Drop Frames
         0 Sup Queue 5 Drop Frames               0 Sup Queue 13 Drop Frames
         0 Sup Queue 6 Drop Frames               0 Sup Queue 14 Drop Frames
         0 Sup Queue 7 Drop Frames               0 Sup Queue 15 Drop Frames
0 Replies 0
