10-24-2013 10:09 PM - edited 03-07-2019 04:13 PM
Hi all,
In a given environement (2x 5k and 2xN7K) with fabricpath we had the following output:
Xxxxxxxxxxx-hostname# show fabricpath isis adjacency
Fabricpath IS-IS domain: default Fabricpath IS-IS adjacency database:
System ID SNPA Level State Hold Time Interface
002a.xxxx.7a81 N/A 1 UP 00:00:30 port-channel2
d867.xxxx.3242 N/A 1 UP 00:00:31 port-channel3
d867.xxxx.32c2 N/A 1 UP 00:00:26 port-channel4
Xxxxxxxx-hostname# show fabricpath isis hostname
Fabricpath IS-IS domain: default dynamic hostname table
Level System ID Dynamic hostname
1 002a.xxxx.4fbc* xxxx-swidce03p
1 002a.xxxx.7a81 xxxx-swidce04p
1 d867.xxxx.3242 xxxx-swidce02p-vdcDC
1 d867.xxxx.32c2 xxxx-swidce01p-vdcDC
I expect normally a mapping takes place (hostname and System-ID)!? This should be through "dynamic hostname" command?!
Also we found an interesting thing on the two switches on the same interface.
On one switch we can configure the speed command and on the other one we can't?! Is there any restriction why it shouldn't possible to configure the speed command?!
Udo
10-25-2013 04:33 AM
That's correct. If you configure the no hostname dynamic within the fabricpath domain default context, then you'll see the switch-ID in hexadecimal format in the output of a number of show commands. I'm not sure why I'd ever do this as it obviously makes troubleshooting more difficult.
In terms of configuring the speed command, can you provide any more details e.g., 5K or 7K, the NX-OS version etc.?
10-25-2013 06:15 AM
I thought the command hostname dynamic is on by default?
In our case show fabricpath isis adjacency shows the MAC Adress of VLAN1 from the parent switch.
Regarding the "speed" command this is on a 5548UP with version 6.0(2)
####peer links#########
interface Ethernet1/9
switchport mode fabricpath
channel-group 2 mode active
interface Ethernet1/10
interface Ethernet1/11
speed auto
interface Ethernet1/12
speed auto
thanks
Udo
10-25-2013 09:54 AM
Hi Udo,
You're correct that hostname dynamic is on by default so it's interesting you're seeing the hexadecimal switch ID. Is this on the Nexus 5K, Nexus 7K or both and which NX-OS versions are you running on those platforms? The output of a show run fabricpath all would be useful if you could post it here.
As far as the speed auto command, this is not something I've can see in any of the switches I've looked at here, and can't reproduce in my lab either. Can you paste the output of a show int eth1/9-12 capabilities and show int eth1/9-12 transceiver?
10-25-2013 10:43 AM
Hi Steve,
The problem with the hostname is on a 7K with NX OS 6.2
Regarding the spees command i can't currently show the output of the required commands because I don't have access to the switches currently.
Maybe in two weeks again. If the problem is still active I will send the informations.
Thanks again Steve...
Udo
