Facing issue while setting up WS-SVC-WISM2-K9 on Cisco 6509 switch
manish_3191
Hi Team,
I am trying to setup WS-SVC-WISM2-K9 on cisco 6509 switch with IOS version 12.2(33)SXJ1.
I have completed the below config and seeing service-port up but not coming in oper-up status.
I have installed WiSM module in slot 8 and seeing TG8/1, T8/2,G8/3 and G8/4 switch ports under module 8.
I am seeing only the automatically created port-channel 415 up with only T8/1 in it which strange to me.
I cant modify those interfaces as seeing error " These interfaces can not be modified.
Please provide suggestion about wht could be the wrong here?
COR-01#sh wism status
Service Vlan : 93, Service IP Subnet : 1.1.1.1/255.255.255.0
      WLAN
Slot  Controller  Service IP       Management IP    SW Version    Controller Type    Status
8     1           0.0.0.0          0.0.0.0                       WS-SVC-WISM-2-K9   Service Port Up
JP2-RDC-COR-01#sh wism module 8 controller 1 status
WiSM Controller 1 in Slot 8 configured with auto-lag
Operational Status of the Controller : Service Port Up
Service VLAN                         : 93
Service Port                         : 3
Service Port Mac Address             : 30e4.db38.9981
Service IP Address                   : 0.0.0.0
Management IP Address                : 0.0.0.0
Software Version                     :
Port Channel Number                  : 415
Allowed-vlan list                    : 90,800,810
Native VLAN ID                       : 90
WCP Keep Alive Missed                : 0
JP2-RDC-COR-01#sh module
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL16084N3K
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL16085AEH
  3   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL16159JHP
  4   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL16085099
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL1550Y2C7
  8    4  WiSM 2 WLAN Service Module             WS-SVC-WISM2-K9    SAL16159DWW
  9   16  CEF720 16 port 10GBaseT                WS-X6716-10T       SAL1626F9HR
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  c464.1305.b274 to c464.1305.b2a3   4.2   12.2(18r)S1  12.2(33)SXJ1 Ok
  2  c464.1387.f5b4 to c464.1387.f5e3   4.2   12.2(18r)S1  12.2(33)SXJ1 Ok
  3  5057.a866.6c98 to 5057.a866.6cc7   4.2   12.2(18r)S1  12.2(33)SXJ1 PwrDown
  4  f0f7.556a.2bc0 to f0f7.556a.2bef   4.2   12.2(18r)S1  12.2(33)SXJ1 PwrDown
  5  5475.d07b.62d0 to 5475.d07b.62d7   4.1   8.5(4)       12.2(33)SXJ1 Ok
  8  0007.7d8c.5390 to 0007.7d8c.539f   1.1   12.2(18r)S1  12.2(33)SXJ1 Ok
  9  442b.034f.7410 to 442b.034f.741f   2.1   12.2(18r)S1  12.2(33)SXJ1 Ok
TenGigabitEthernet8/1  unassigned      YES unset  up                    up
TenGigabitEthernet8/2  unassigned      YES unset  down                  down
GigabitEthernet8/3     unassigned      YES unset  up                    up
GigabitEthernet8/4     unassigned      YES unset  administratively down down
COR-01(config)#int g8/4
% This interface cannot be modified
Version 12.2(33)SXJ1
ip dhcp excluded-address 1.1.1.1
ip dhcp pool WiSM_service_Port
   host 1.1.1.2 255.255.255.0
   hardware-address 30e4.db38.a8c1
wism service-vlan 93
wism module 8 controller 1 allowed-vlan 90,800,810
wism module 8 controller 1 native-vlan 90
interface Vlan93
description WiSM service port do not route-Inner Chassis WiSM to Supervisor connection
ip address 1.1.1.1 255.255.255.0
COR-01#sh etherchannel summary
415    Po415(SU)        -        Te8/1(P)
7 Replies 7
Leo Laohoo
Your Service Port VLAN (93) is NOT ALLOWED.
I have tried allowing vlan 93 but didnt work. I ahve run debug wism events on Cat6509 and seeing below logs:
Aug 17 02:44:26.035: WiSM-Evt:dman_show_module_status: Port Channel in the hwidb/fec goup is :1/415
Aug 17 02:44:26.799: WiSM-Evt:dman_cntrl_db_search_by_mac: Found mac 30e4.db38.9981 for slot/port 8/1
Aug 17 02:44:26.799: WiSM-Evt:dman_reg_arp_added: cntrl 8/1 got an ip 1.1.1.3 30e4.db38.9981/30e4.db38.9981
Aug 17 02:44:26.799: WiSM-Evt:dman_reg_arp: received a garp from 1.1.1.3/1.1.1.3
Aug 17 02:44:40.019: WiSM-Evt:dman_reg_arp: received a garp from 1.1.1.2/1.1.1.2
Aug 17 02:44:42.127: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 8/1
Aug 17 02:44:42.127: WiSM-Evt:dman_cntrl_db_search: something wrong 15
Operational Status of the Controller : Started KeepAlive
Service VLAN                         : 93
Service Port                         : 3
Service IP Address                   : 1.1.1.3
Software Version                     :
Allowed-vlan list                    : 90,93,800,810
Native VLAN ID                       : 90
Can you please post the output to the command "sh run | i wism module 8 controller 1"?
COR-01#sh run | inc wism module 8 controller 1
wism module 8 controller 1 allowed-vlan 90,93,800,810
Forgot to ask if you can also post the output to the command "sh wism module 8 controller 1 status".
Service VLAN                         : 93
Service Port                         : 3
Software Version                     :
Native VLAN ID                       : 90
Also providing Controller interface summary output. I have not used DHCP here. Assigned static ips.
(Cisco Controller) >show interface summary
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
management                       LAG  untagged 10.76.12.12     Static  Yes    No
service-port                     N/A  N/A      1.1.1.3         Static  No     No
virtual                          N/A  N/A      2.2.2.2         Static  No     No
You are not allowed to modify the etherchannel ports.  It's normal.
If you need to, you can only console into the WiSM 2 or you use the command to session in:  session slot 8 process 1
Command needs to be run in the 6500.
