fails post
andrewerowley
Community Member
C3750 switch fails post with the following-
Waiting for Stack Master Election (around 30 seconds)...
POST: PortASIC CAM Subsystem Tests : Begin
TCAM (asic:4) walking-one test failed
Write: 80_00000000_01000000-00_00000000_00000000
Read: 80_00000000_01800000-00_00000000_00000000
POST: POST Failed
POST: PortASIC CAM Subsystem Tests : End, Status Failed
POST: CAM test failed
POST Failed: disabling stack links and shutting down SDP
driver class subsystem initialization failed
!!! WARNING: The switch is not usable !!!
Unable to create l2trace server process, socket_open() failed
any informayion on the causes of this?and is their a remedy?
Richard Burts
andrew
Based on these error messages I would believe that the problem was a hardware error in the switch. I believe that the appropriate thing to do is to open a case with Cisco TAC about this.
Rick
Rick
Thanks very much,case opened with TAC and all sorted.
Hello. I'd like to know what was the reply you had from CISCO and how you solved this issue? By the way I am experiencig the same problem:
TCAM (asic:1) walking-one test failed
Write: 80_00000000_00000000-00_00000000_10000000
Read: 80_FFFFFFFF_00000000-00_00000000_10000000
POST: POST Failed
"Switch is unusable!"
Thanks, Douglas.
