FAN PS-1 is NOT INITIALIZED
HCL Support
Hi ,
Please analyse logs and update if any bug affected..
System image file is "flash:c3560e-universalk9-mz.122-55.SE10.bin"
cisco WS-C3560X-48 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Log Buffer (4096 bytes):
16 08:30:11.402 +GMT: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
Aug 23 2016 08:35:29.197 +GMT: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
Aug 23 2016 08:40:46.220 +GMT: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
Aug 23 2016 08:46:04.355 +GMT: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
Aug 23 2016 08:51:21.434 +GMT: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
Aug 23 2016 08:56:39.341 +GMT: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
Aug 23 2016 09:01:57.436 +GMT: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
Mark Malone
please post the show env all see whats down
also did you put eyes on back of the switch see if any of the PS are green or amber ? if one is amber reseat it see if it comes back up
We have reseat many time but after some time it is showing red with same status as given in "show env all"
------------------ show env all ------------------
FAN 1 is OK
FAN 2 is OK
FAN PS-2 is OK
TEMPERATURE is OK
Temperature Value: 28 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold : 60 Degree Celsius
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A C3KX-PWR-350WAC LIT14180AFZ No Input Power Bad N/A 350/0
1B C3KX-PWR-350WAC LIT14180AVS OK Good Good 350/0
SW Status RPS Name RPS Serial# RPS Port#
1 Not Present <>
if its red its most likely blown , you could swap them around make sure its not the slot but I would say its the PS , as well make sure there's nothing wrong with the feed going into it by swapping the ps cables around , if its still the same replace it
There is a lot of bugs for power supply's mostly ios-xe where it shows as down in show env but when you actually look at it its still up and working , I don't think you have hit a bug I think you need to replace the PS
