Feature "Web-Based Proxy Authentication" in Catalyst 6500s run IOS
nvanphuong
Hi all,
Is there any feature like "Web-Based Proxy Authentication" in catalyst 6500 run IOS?
I saw that in Catalyst 6500 running CatOS but in IOS. Can anyone show me the similar feature in IOS.
Thanks in advance,
Phuong@
Craig Balfour
Cisco's Firewall IOS has authentication proxy support (http://www.cisco.com/en/US/customer/products/sw/secursw/ps1018/products_tech_note09186a0080094eb0.shtml) but Firewall IOS is only supported on some Cisco routers, not Catalyst switches.
Iain
Level 4
Level 4
Phuong,
You need to check Feature Navigator.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
When I do a search for these features "Firewall Feature Set" & "Firewall Authentication Proxy", I show that there are numerous Sups in the 6500 series which DO support both the features you're interested in.
Most of the images required are ADVANCED ENTERPRISE SERVICES level. So depending on your hardware you may require RAM upgrades to run them.
pls rate if helpful
Amit Singh
Phuong,
"Web-Based Proxy Authentication" for users without 802.1x client is only supported on CtaOS at this point of time. We donot siupport that feature in cisco IOS at this point of time. This feature will be available on Cisco IOS shortly.
HTH,Please rate if it does.
-amit singh
Thanks for your informations, they are very useful.
