Fiab base configuration example...
m-avramidis
Level 3
Level 3
Hello, I have always used a script when doing a Fiab site (customer created the script) but never configured a Fiab from scratch (i.e out of the box), I know how to configure the (fiab) site in DNA but not which base configuration that is needed in order for DNA do access the box. I mean except for BGP, VRF, Loopback, WAN config (in this case the site will be behind a ASA and we will run BGP between the box and ASA), user pwd/keys, DNS, NTP.... is there anything more that is needed?
Have not been able to find any base configuration examples (cli)
Any help and/or pointers will be most appreciated
...."why not use the script you have after you modify it?" Well...a NDA prohibits that 🙂
pieterh
" base configuration that is needed in order for DNA to access the box  "
that depends,
if your environment is configured for DNA-PnP then you only need to connect the switch to your network on a PnP enabled port
the switch will request a DHCP address, try to discover a PnP server, find DNA, and register itself with DNA
then from in "inventory -> PnP -> unclaimed" you will find the new switch and "claim the device" (=run the script)
