Fiber uplinks
uma.kashi
Hi ,
I wanted to know can we have all fiber uplinks to a switch,if yes which model supports it.
Uma
Hello
These switches can act as a distribution core for your access closets:
WS-C3750G-12S-S
or
WS-C3750X-12S-S
res
Paul
Kind Regards
Paul
Hi uma,
There is a variety of switch that support fiber up links. What specific part of the network are you thinking of adding the switch to? and what are the features you are looking for in a switch like port numbers and would it support POE. please feel free to send me an email at fguasque@cisco.com
fguasque@cisco.com
Hi ,
I Have attached the diagram ,in the diagram you can see all the L2 swicthes will be connected to L3 switch.
I am looking at L3 switch where i want all the fiber uplinks to be conencted ,the role of the switch is L3 it will have all the vlans connected and it also connected to WAN conenctions at the location.
Please suggest.
Uma
How many fibres per "building"?  If you want a 12-port fibre optic switch, then the cheapest is WS-C3750X-12S.  If you want 24-port fibre optic switch then its WS-C3750X-24S.
