Fibre connection query re SRW2048 switch
acceler8cco
Hi, probably a basic question but hoping someone can assist. I have a client with this on site and it has 3x GB connections.  We have connected ST-SC copper fibre converter cables to this however on the other end the fibre switch is only 10/100 and there are no lights on the 2048 GB ports and the cables are not working. I'm wanting to know if its going from GB  to 10/100 that would be the problem?  Thanks for any help.
Reza Sharifi
Hi Mike,
Yes, that is the problem.  The fiber interface is Gig only and does not work with 10/100.  With Fiber both sides have to use the same speed.
Reza
Thanks so much for your help and the quick reply.
