Find unused ports for since 14 weeks
beta_admin66
I would like to call up the ports on a switch that have not been used for 14 weeks. I have given this command:
show int | i proto.*notconnect|proto.*administratively down|Last in.* [14]w|Last in.*[0-9][0-9]w|[0-9]y|disabled|Last input never, output never, output hang never
Is the command correct?
What does mean .*[0-9][0-9]w|[0-9]" ?
Thank you very much.
7 Replies 7
beta_admin66
What does mean this output ?
GigabitEthernet1/0/1 is down, line protocol is down (notconnect)
Was this port never in use?
Hello @beta_admin66 ,
it means the port has never been up/up since last reload of the switch.
However, be aware that on some platforms and IOS version the sentence
appear also for ports that are in up/up with an input rate and an output rate.
This is a SW bug or SW limitation. You need to check the appearence of the line for ports that are up/up
Hope to help
Giuseppe
It is a Cisco Catalyst 2950, WS-C2950G-48-EI.
Leo Laohoo
What is the model of the switch?
If the switch is a Catalyst 4k, then use the command "sh interface link".
I also noticed something else:
switchxy>show int | i proto.*notconnect|proto.*administratively down|Last in.* [14]w|Last in.*[0-14][0-14]w|[0-9]y|disabled|Last input never,output, output hang never
FastEthernet0/35 is down, line protocol is down (notconnect) -> here is no output about the weeks/year
switchxy>show int FastEthernet0/35
Last input 36w2d, output 36w2d, output hang never --> here is an output about the weeks/year
What does this mean: .*[0-14][0-14]w|[0-9]  ?
Thank you
refers to last input and output parameters. You will only see anything that is equal or less to 14 weeks. If you want to include a higher number, you have to change the parameters marked in bold:
It is a regular expression that is a way to match variable strings or patterns. However, I think a more correct syntax should be:
.*[1-9][4-9]w[0-9]
the .* means one of more occurrences of the following pattern.
The pattern is made of characters taken from a set the set in square brackets,  in this case we would like the first char to be 1 or greater and the second char to be 4 to 9 in this way you should be able to match all ports unused for 14 weeks or more. The w is literaly the w character the subsequent is a don't care.
Hope to help
Giuseppe
