Firewall 8.4 software issue
midlajnp1
Visitor
If I update 8.4 sw To overcome IKEv1 and IKEv2 buffer overflow vulnerability, What are the steps?please help me.
  1. Load the image asa847-30-k8.bin from Cisco.com.
  2. Read the release notes if there are additional steps needed after upgrade (which depends on the 8.4 version you are running at the moment).
  3. If needed, delete old files from flash to make room for the new image.
  4. In ASDM, go to Tools -> Software Upgrade from local Computer.
  5. Choose ASA, your downloaded file and load the image to the ASA.
  6. When asked, confirm to set the new image as the boot-image.
  7. Reload
  8. Test all functionality and correct problems if they show up.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Many thanks.....
