Firewall (fwsm) in catalyst 6500
lukasz.brzosko
I've a question, about a policy-map, class-map and other policy command!
In catalyst 6500 switch with firewall module i can't configure policy the command that I wrote above are only in switch IOS but when I make a session to fwsm there are non of them :( just like the fwsm IOS doesn't supprt them! In cisco guide about fwsm (3.1) this command are also present on fwsm not only switch IOS. What is the cause of this? what I done wrong or what I didn't do but I should??
thx for any advice!
b.speltz
Level 4
Level 4
TCP connection has two Initial Sequence Numbers (ISNs): one generated by the client and one generated by the server. The FWSM randomizes the ISN.Refer URL
http://www.cisco.com/en/US/products/hw/switches/ps708/products_module_configuration_guide_chapter09186a0080577c66.html
Well the true reason of my trouble was my stupidity ;) I should bang in to my head.
I never tought to check the IOS wer. i assume it was the newest one but IT WASN'T! in my wer. there is no inspect just fixup so there isn't any command policy-map or class-map :) i already
have the guide for my wer. of IOS
Thx
