Firewall on a stick
sarath92
i All,
I was configuring a set up in packet tracer similar to router on a stick. Only difference is that we got a Cisco ASA firewall in between router and the switch as below:
The port from switch to firewall has been made trunk from the switch end. I have given two sub-interfaces in router to facilitate two V-LANs. Now my doubt is how should I configure the firewall ports. I am not able to create a sub interface in firewall. Also I don't know how to create a trunk port in firewall. Please help me out with the commands if any. Forgive me for being a Noob :)
Ahh! I remember this insane limitation on the ASA5005 Base license!! Essentially you have to nominate one VLAN which is not allowed to initiate communication with the other two....not what we want.
So, lets move the routing of the two INSIDE subnets onto switch0 and configure the ASA with just two interfaces:
! switch0
vlan 3,10,20
int vlan3
  desc FW-TRANSIT
  ip address 172.3.10.1 255.255.255.252
no shut ! int vlan 10 desc INSIDE-10 ip address 172.10.10.254 255.255.255.0 no shut ! int vlan 20 desc INSIDE-20 ip address 172.20.10.254 255.255.255.0 no shut ! int gi1/0/1 desc TO_ASA switchport trunk encapsulation dot1q switchport mode trunk switchport trunk allowed vlan 3 no shut !
ip routing
ip default-gateway 172.3.10.2
! ASA
int vlan 2
  ip address 172.0.10.100 255.255.255.0
  nameif OUTSIDE
  security-level 0
  no shut
int vlan 3
  ip address 172.3.10.2 255.255.255.252
  nameif INSIDE
  security-level 100
  no shut
int eth0/0
int eth0/1
  switchport mode access
  switchport access vlan 2
  no shut
object network VLAN10
  subnet 172.10.10.0 255.255.255.0
  nat (INSIDE,OUTSIDE) dynamic interface
object network VLAN20
  subnet 172.20.10.0 255.255.255.0
route OUTISDE 0.0.0.0 0.0.0.0 172.0.10.99 1
Connect:
Switch0|Gi1/0/1 <---> eth0/0|ASA|eth0/1 <---> Gi0/1|Router
If you didn't want to use Auto NAT config as part of a network object you could use the following Manual NAT config:
nat (INSIDE,OUTSIDE) source dynamic VLAN10 interface
nat (INSIDE,OUTSIDE) source dynamic VLAN20 interface
cheers,
Seb.
Seb Rupik
Hi there,
The ASA5505 does not support routed interfaces, but instead uses SVIs for routing.
Your ASA interface config will look like:
int vlan 2
  nameif OUTSIDE
  security-level 0
  no shut
int vlan 10
  nameif INSIDE-10
  security-level 100
  no shut
int vlan 20
  nameif INSIDE-20
  security-level 100
  no shut
int eth0/0
  switchport trunk allowed vlan 10,20
int eth0/1
  no shut
  nat (INSIDE-10,OUTSIDE) dynamic interface
  nat (INSIDE-20,OUTSIDE) dynamic interface
On the router, configure a normal routed interface and connect it to ASA eth0/1 :
no int gi0/1.1
no int gi0/1.2
int gi0/1
  ip address 172.0.10.99 255.255.255.0
  no shut
ip route 172.10.10.0 0.0.0.255 172.0.10.100
ip route 172.20.10.0 0.0.0.255 172.0.10.100
cheers,
Seb.
Hi Seb,
Thanks for your answer
I am getting below error when trying to configure more than one nameif interface:
ERROR: This license does not allow configuring more than 2 interfaces with nameif and without a "no forward" command on this interface or on 1 interface(s) with nameif already configured.
Does packet tracer does not support this?
Also is there a method to enable NAT using only IP address rather than network object?
! switch0
vlan 3,10,20
int vlan3
  desc FW-TRANSIT
ip routing
! ASA
int vlan 2
  nameif OUTSIDE
  security-level 0
  no shut
int vlan 3
  nameif INSIDE
  security-level 100
  no shut
int eth0/0
int eth0/1
  no shut
Connect:
cheers,
Seb.
Yes ! It worked. Thank you
