firewalls and web tunneling software
carl_townshend
hi all, if we use a ASA, application layer firewall, how does things like gotpmypc remote access software manage to tunnel through it, i would of thought the http inspection would block it,
what exactly happens ?
carl_townshend
can anyone help on this at all?
Cheers
Carl
hi,
i think you might closed ports for vpn access. try search some document on remote access over ASA or which relevant port needs to be open for your software (gotmypc) to work.
hi, can anyone add to this? I would like to know how it works ?
