First configuration Cisco Nexus N9K
lina.haddad
Hi everyone,
I just received a N9K switch from the factory and I don't know how to configure it.
It starts and displays several log messages and stops.
Can you please give me any links or your knowledge when setting up an N9K switch for the first time.
Thanks for your help,
Lina
6 Replies 6
Mark Elsen
 - FYI https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/fundamentals/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Fundamentals_Configuration_Guide/b_Cisco_Nexus_9000_Series_NX-OS_Fundamentals_Configuration_Guide_chapter_010....
  If , however, you think the system has a fundamental problem then post a console log (preferably simple-ascii) or else a screenshot.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
lina.haddad
Hello marce1000,
Thanks for your reply.
Bellow the logs i can see :
2021 Dec 9 15:27:09 switch %$ VDC-1 %$ last message repeated 1 time
2021 Dec 9 15:27:09 switch %$ VDC-1 %$ %POAP-2-POAP_DHCP_DISCOVER_START: [FDO240704VG-24:16:9D:61:3D:87] - POAP DHCP Discover phase started
2021 Dec 9 15:27:09 switch %$ VDC-1 %$ %POAP-2-POAP_FAILURE: [FDO240704VG-24:16:9D:61:3D:87] - POAP DHCP discover phase failed
2021 Dec 9 15:27:11 switch %$ VDC-1 %$ %PLATFORM-1-PFM_ALERT: System will shutdown in 0 minutes 10 seconds due to fan policy __pfm_fanabsent_multi_fan.
2021 Dec 9 15:27:12 switch %$ VDC-1 %$ %PLATFORM-2-PFM_SYSTEM_SHUTDOWN_TRIGGER: System shutdown due to FanAbsent policy trigger
2021 Dec 9 15:27:14 switch %$ VDC-1 %$ %POAP-2-POAP_INFO: [FDO240704VG-24:16:9D:61:3D:87] - USB Initializing Success
2021 Dec 9 15:27:14 switch %$ VDC-1 %$ %POAP-2-POAP_INFO: [FDO240704VG-24:16:9D:61:3D:87] - USB disk not detected
2021 Dec 9 15:27:14 switch %$ VDC-1 %$ last message repeated 1 time
2021 Dec 9 15:27:14 switch %$ VDC-1 %$ %POAP-2-POAP_DHCP_DISCOVER_START: [FDO240704VG-24:16:9D:61:3D:87] - POAP DHCP Discover phase started
2021 Dec 9 15:27:14 switch %$ VDC-1 %$ %POAP-2-POAP_FAILURE: [FDO240704VG-24:16:9D:61:3D:87] - POAP DHCP discover phase failed
- This device is experiencing hardware issues apparently. Contact TAC for
further assistance. It may need replacement (RMA). M.
       Beauty and terror
      Just keep going
       No feeling is final
lina.haddad
we've just received this switch from an RMA of another switch.
Thanks marce1000 for your help. I'll contact TAC
lina.haddad
another constation : the STN Led is red !
Bad news!
       Beauty and terror
      Just keep going
       No feeling is final
