Flash and DRAM help
qbakies11
Level 4
Level 4
I need to upgrade my IOS to 12.4(11)XW to support my HWIC-1ce1t1-pri card and PVDM2 module. I have a 2811 router that I just bought last December and I was told it was going to have 256MB DRAM and 64MB Flash (which is what is required to run the IOS I need to upgrade to). When I looked at the router though it look like I don't actually have enough.
SHOW VERSION:
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(3h), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 25-Jul-07 15:20 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
DaytonGW uptime is 6 days, 4 hours, 53 minutes
System returned to ROM by reload at 07:30:59 NewYork Sat Mar 8 2008
System image file is "flash:c2800nm-ipbase-mz.124-3h.bin"
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FTX1146A0X3
2 FastEthernet interfaces
1 Serial interface
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
SHOW FLASH:
-#- --length-- -----date/time------ path
1 15678960 Nov 13 2007 01:58:04 -05:00 c2800nm-ipbase-mz.124-3h.bin
2 1823 Nov 13 2007 02:06:32 -05:00 sdmconfig-2811.cfg
3 6036480 Nov 13 2007 02:07:10 -05:00 sdm.tar
4 861696 Nov 13 2007 02:07:26 -05:00 es.tar
5 1164288 Nov 13 2007 02:07:46 -05:00 common.tar
6 1038 Nov 13 2007 02:08:02 -05:00 home.shtml
7 113152 Nov 13 2007 02:08:18 -05:00 home.tar
8 1697952 Nov 13 2007 02:08:48 -05:00 securedesktop-ios-3.1.1.45-k9.pkg
9 416354 Nov 13 2007 02:09:20 -05:00 sslclient-win-1.1.3.173.pkg
38027264 bytes available (25989120 bytes used)
Do I actually have enough for the new IOS?
Richard Burts
Quinton
What you have posted does show that the router has 256 MB of memory and 64 MB of flash. I am not clear what the requirements of your new image are. But you currently have 38027264 available in flash and you could free up 15678960 if you delete the existing image. I can not imaging an image for which this would not be enough flash.
What is it that makes you think that you may not have enough?
Rick
Rick
Richard Burts
Quinton
Rick
Rick
Thanks for the verification.
Quinton
You are quite welcome. I am glad that my response was helpful. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read a response which did resolve the question.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
Rick
