Flash contents
jplenbrook
Hi all,
We purchased 3 used Cisco Catalyst 3750G switches.
I have removed vlan.dat, I did write erase however there are some other files on the flash.
Switch#show flash
Directory of flash:/
    3  -rwx        5830   Mar 1 1993 00:02:38 +00:00  config.text.backup
    5  -rwx           5   Mar 1 1993 00:02:38 +00:00  private-config.text.backup
  429  drwx         192   Mar 1 1993 00:21:28 +00:00  c3750-ipbase-mz.122-50.SE3
    6  -rwx       26722  Sep 15 2013 15:02:38 +00:00  config.text.renamed
32514048 bytes total (20136448 bytes free)
Can I delete .backup files & config.text.renamed? Should new Catalyst only have IOS on the flash?
Thanks.
Leo Laohoo
Yes.
hi
Thanks for that.
Should a new Cisco Catalyst only include IOS on the flash? No any other files?
IOS, VLAN.dat file and config.text file.
