Flash hardware upgrade (Cisco 2501 router)
lazon
I need to upgrade my Flash memory in order to accomodate the latest IOS (12.3)for my Cisco 2501 router. I purchased 2-8 MB Flash memory. I installed the 2 Flash memory sticks but it's showing 2 partitions (1 & 2), how can I combine these 2 partition to make 1 single partition with 16 MB total. Thank you in advance and I really appreciate your help.
Martin Parry
Level 3
Level 3
Erase the flash then enter the command
partition flash 1
which will create a single flash memory partition.
Please see below url:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1824/prod_release_note09186a008007fb5f.html#xtocid9
Hope this helps
Martin
