Flash player issue with IE browser when run CCP.
mardhincisco
Hi guys, I have installed CCP v 2.8 and also flash player v29 active x.
when I want to run my CCP, It always shows "Adobe Flash Player is required to run Cisco Configuration Professional. You do not have Adobe Flash Player installed in your system. Exit Cisco Configuration Professional, install the Adobe Flash Player, and then start Cisco Configuration Professional."instruction.
Eventhough I have many times install higher version flash player than they required.
I also have enable the flash player on my IE.
could you guys help me about this issue. I am very stuck on it.
try using the full desktop version, it is about 165MB in size.
Here is the download link (scroll down to  'CISCO CONFIGURATION PROFESSIONAL (DESKTOP VERSION)':
http://www.firewall.cx/downloads/cisco-tools-a-applications.html
