flash running out of space
TerenceChan99
dear all,
I want to upgrade my C3650-24TS from 03.06.06E to 16.09.06 with below command
software install file flash:cat3k_caa-universalk9.16.09.06.SPA.bin new force
but the processes is failed as flash memory is not enough. Any items of below can be deleted?
54210  -rw-    83293932  Aug 17 2017 06:45:35 +08:00  cat3k_caa-base.SPA.03.06.06E.pkg
54211  -rw-     3982012  Aug 17 2017 06:45:36 +08:00  cat3k_caa-drivers.SPA.03.06.06E.pkg
54212  -rw-    33788908  Aug 17 2017 06:45:35 +08:00  cat3k_caa-infra.SPA.03.06.06E.pkg
54213  -rw-    43074880  Aug 17 2017 06:45:35 +08:00  cat3k_caa-iosd-universalk9.SPA.152-2.E6.pkg
69697  -rw-    28394380  Aug 17 2017 06:45:35 +08:00  cat3k_caa-platform.SPA.03.06.06E.pkg
69698  -rw-   111233856  Aug 17 2017 06:45:36 +08:00  cat3k_caa-wcm.SPA.10.2.160.0.pkg
   12  -rw-        1236  Aug 17 2017 06:45:49 +08:00  packages.conf
61953  drwx        4096  Aug 17 2017 06:50:18 +08:00  dc_profile_dir
   11  -rw-     2097152  Aug 15 2020 14:38:27 +08:00  nvram_config
   13  -rw-         616  Aug 15 2020 14:32:25 +08:00  vlan.dat
   14  -rw-   450568480   Apr 8 2021 12:16:55 +08:00  cat3k_caa-universalk9.16.09.06.SPA.bin
61957  -rw-    19862144  Apr 17 2021 11:08:52 +08:00  cat3k_caa-guestshell.16.09.06.SPA.pkg
61958  -rw-    30872219  Apr 17 2021 11:08:52 +08:00  cat3k_caa-rpbase.16.09.06.SPA.pkg
61959  -rw-   373863032  Apr 17 2021 11:08:53 +08:00  cat3k_caa-rpcore.16.09.06.SPA.pkg
61960  -rw-     3156608  Apr 17 2021 11:08:53 +08:00  cat3k_caa-srdriver.16.09.06.SPA.pkg
61961  -rw-    22809212  Apr 17 2021 11:08:54 +08:00  cat3k_caa-webui.16.09.06.SPA.pkg
1621966848 bytes total (411041792 bytes free)
13 Replies 13
Leo Laohoo
What is the uptime of the switch?
I know there is a "time bomb" bug with 3.6.X and 3.7.X involving the extraction of package files when the switch/stack has a very high uptime of >1 year.
The "fix" is to reboot the switch and re-run the package extraction command.
Leo Laohoo
Delete everything from the from the following folders:  core, crashinfo
del /f /r flash:core/*
del /f /r crashinfo:*
TerenceChan99
I tried reload before start the upgrade. but it is still failed due to not enough space in flash.
Dear Leo,
the folder flash: core/* and crashinfo:* only have a few files that should have no help.
Any suggestion? What file in the flash can be removed?
Ok, let's do this by the numbers:
  1. Is this a stack of switches or a single stack?
  2. Post the complete output to the following commands:
dir flash-X:
dir flash-X:/core
dir crashinfo-X:
NOTE:  "X" means switch stack number.
Dear Leo,
Thank a lot for your help.
it is single stack:
Switch Ports Model SW Version SW Image Mode
* 1 28 WS-C3650-24TS 03.06.06E cat3k_caa-universalk9 INSTALL
CORE-SW#dir flash:
Directory of flash:/
61953 drwx 4096 May 8 2021 21:43:56 +08:00 dc_profile_dir
11 -rw- 2097152 May 8 2021 21:44:31 +08:00 nvram_config
1621966848 bytes total (410640384 bytes free)
CORE-SW#dir flash:/core
%Error opening flash:/core (No such file or directory)
CORE-SW#dir flash:crashinfo
%Error opening flash:/crashinfo (No such file or directory)
Please post the complete output to the command "sh version".
CORE-SW#sh version
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.06.06E RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sat 17-Dec-16 00:22 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 3.56, RELEASE SOFTWARE (P)
CORE-SW uptime is 5 days, 16 hours, 27 minutes
Uptime for this control processor is 5 days, 16 hours, 30 minutes
System returned to ROM by reload
System image file is "flash:packages.conf"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Lanbase
License Type: Permanent
Next reload license Level: Lanbase
cisco WS-C3650-24TS (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FDO2133Q0Q9
2 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of at webui:.
Base Ethernet MAC Address : 70:7d:b9:36:5f:00
Motherboard Assembly Number : 73-15898-06
Motherboard Serial Number : FDO213305V5
Model Revision Number : Q0
Motherboard Revision Number : A0
Model Number : WS-C3650-24TS
System Serial Number : FDO2133Q0Q9
Configuration register is 0x102
CORE-SW#
Ooops.  Looks like I provided the wrong info.  The correct syntax should be "dir crashinfo:".
What command was used to extract the packages off the BIN file?
User Access Verification
Username: cisco
Password:
CORE-SW#dir crashinfo:
Directory of crashinfo:/
11 -rw- 544 May 8 2021 21:39:02 +08:00 last_systemreport_log
12 -rw- 0 Jan 1 1970 08:00:04 +08:00 koops.dat
13 -rw- 0 May 8 2021 21:41:54 +08:00 cilogs
248354816 bytes total (248352768 bytes free)
CORE-SW#
install command:
What is the exact error message?
Is it just saying that the flash is almost full?
Please refer to below, it seem the flash doesn't have enough space for the installation process.
CORE-SW#$stall file flash:cat3k_caa-universalk9.16.09.06.SPA.bin new force
Preparing install operation ...
[1]: Starting install operation
[1]: Expanding bundle flash:cat3k_caa-universalk9.16.09.06.SPA.bin
[1]: Copying package files
[1]: Package files copied
[1]: Finished expanding bundle flash:cat3k_caa-universalk9.16.09.06.SPA.bin
[1]: Verifying and copying expanded package files to flash:
[1]: % flash: requires 440005 KB of free space, but only 401008 KB is available. Operation aborted.
[1]: % An internal error was encountered. Operation aborted.
CORE-SW#
Ok, I got a workaround for this stupidity:
  1. Copy the IOS to the flash:
  2. Force the switch to boot the new flash in BUNDLE Mode
  3. After the switch boots into bundle mode, clean the flash so the old files will get deleted
  4. Run the Install Mode procedure
  5. Change the boot variable string to point to the "packages.conf" file.
  6. [OPTIONAL]  Reboot the switch.
TerenceChan99
It seem I can't install from Flash directly as I don't have enough space for that. How about install from USB drive or tftp? Is it allowed? If yes, how to do so?
